Icinga Web 2 is using UTF-8 as encoding, so it definitely supports Chinese characters. You should check the charset you’ve configured for the IDO resource in Icinga Web 2. Which should be latin1, despite you wanting to show non-ASCII chars I know, just use it
If this doesn’t already help… please head back, though it hopefully does help.
Have you solved the problem?
not yet。The encoding of the icinga web2 database is utf-8,but chinese still can not show in icingaweb2.
wo have solved it…i update the file /etc/icingaweb2/resources.ini,
[icinga_ido]
type = “db”
db = “mysql”
host = “...”
port = “”
dbname = “"
username = "”
password = “****”
charset = “latin1”
change charset to latin1
it works! Thanks very much!
