root@afnan:~# icingacli setup config webserver nginx --document-root /usr/share/icingaweb2/public --config /etc/icingaweb2 -fpm-uri 127.0.0.1:9000
ERROR: There is no such module or command: ‘setup’
USAGE: icingacli [module] [action] [options]
Available commands:
help Help for modules, commands and actions
module List and handle modules
web
Available modules:
doc
monitoring
Global options:
–log [t] Log to , either stderr, file or syslog (default: stderr)
–log-path Which file to log into in case of --log file
–verbose Be verbose
–debug Show debug output
–help Show help
–benchmark Show benchmark summary
–watch [s] Refresh output every seconds (default: 5)
Show help on a specific command : icingacli help
Show help on a specific module : icingacli help
I am trying to set up Icinga on a server which runs iredmail (postfix) served by nginx. I have followed the instructions above, to no avail (“File not found”). Here is by nginx configuration (nginx -T). The section related to icinga is at the very end of the configuration. Do you see anything obvious that needs to be changed?
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
# configuration file /etc/nginx/nginx.conf:
user www-data;
worker_processes 1;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/conf-enabled/*.conf;
include /etc/nginx/sites-enabled/*.conf;
# configuration file /etc/nginx/conf-enabled/0-general.conf:
map_hash_bucket_size 1024;
# configuration file /etc/nginx/conf-enabled/cache.conf:
map $sent_http_content_type $expires {
default off;
application/x-javascript 1d;
text/css 1d;
~image/ 1d;
expires $expires;
# configuration file /etc/nginx/conf-enabled/client_max_body_size.conf:
client_max_body_size 12m;
# configuration file /etc/nginx/conf-enabled/default_type.conf:
default_type application/octet-stream;
# configuration file /etc/nginx/conf-enabled/gzip.conf:
gzip on;
gzip_vary on;
gzip_http_version 1.0;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_min_length 10240;
gzip_proxied any;
gzip_disable "MSIE [1-6]\.";
# text/html is always compressed.
gzip_types
text/plain
text/css
text/xml
text/javascript
text/json
text/vcard
text/cache-manifest
text/vnd.rim.location.xloc
text/vtt
text/x-component
text/x-cross-domain-policy
image/bmp
image/vnd.microsoft.icon
image/x-icon
image/svg+xml
font/truetype
font/opentype
application/atom+xml
application/javascript
application/json
application/ld+json
application/vnd.geo+json
application/manifest+json
application/x-font-ttf
application/x-web-app-manifest+json
application/xml
application/xml+rss
application/xhtml+xml
application/vnd.ms-fontobject;
# configuration file /etc/nginx/conf-enabled/headers.conf:
add_header X-Frame-Options sameorigin;
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection '1; mode=block';
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
add_header Content-Security-Policy "default-src https: data: 'unsafe-inline' 'un safe-eval'";
add_header Referrer-Policy strict-origin;
# configuration file /etc/nginx/conf-enabled/log.conf:
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# configuration file /etc/nginx/conf-enabled/mime_types.conf:
include /etc/nginx/mime.types;
# configuration file /etc/nginx/mime.types:
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document d ocx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet x lsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation p ptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/conf-enabled/php_fpm.conf:
upstream php_workers {
server 127.0.0.1:9999;
# configuration file /etc/nginx/conf-enabled/sendfile.conf:
sendfile on;
# configuration file /etc/nginx/conf-enabled/server_tokens.conf:
# Hide Nginx version number
server_tokens off;
# configuration file /etc/nginx/conf-enabled/types_hash_max_size.conf:
types_hash_max_size 2048;
# configuration file /etc/nginx/sites-enabled/00-default-ssl.conf:
# Note: This file must be loaded before other virtual host config files,
# HTTPS
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name _;
root /var/www/html;
index index.php index.html;
include /etc/nginx/templates/misc.tmpl;
include /etc/nginx/templates/ssl.tmpl;
include /etc/nginx/templates/iredadmin.tmpl;
include /etc/nginx/templates/roundcube.tmpl;
include /etc/nginx/templates/sogo.tmpl;
include /etc/nginx/templates/netdata.tmpl;
include /etc/nginx/templates/php-catchall.tmpl;
include /etc/nginx/templates/stub_status.tmpl;
include /etc/nginx/templates/icingaweb2.tmpl;
# configuration file /etc/nginx/templates/misc.tmpl:
# Allow access to '^/.well-known/'
location ~ ^/.well-known/ {
allow all;
access_log off;
log_not_found off;
autoindex off;
#root /var/www/html;
# Deny all attempts to access hidden files such as .htaccess.
location ~ /\. { deny all; }
# Handling noisy messages
location = /favicon.ico { access_log off; log_not_found off; }
location = /robots.txt { access_log off; log_not_found off; }
# configuration file /etc/nginx/templates/ssl.tmpl:
ssl_protocols TLSv1.2;
# Fix 'The Logjam Attack'.
ssl_ciphers EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH;
ssl_prefer_server_ciphers on;
ssl_dhparam /etc/ssl/dh2048_param.pem;
# To use your own ssl cert (e.g. "Let's Encrypt"), please create symbol link to
# ssl cert/key used below, so that we can manage this config file with Ansible.
# For example:
# rm -f /etc/ssl/private/iRedMail.key
# rm -f /etc/ssl/certs/iRedMail.crt
# ln -s /etc/letsencrypt/live/<domain>/privkey.pem /etc/ssl/private/iRedMail.key
# ln -s /etc/letsencrypt/live/<domain>/fullchain.pem /etc/ssl/certs/iRedMail.crt
# To request free "Let's Encrypt" cert, please check our tutorial:
# https://docs.iredmail.org/letsencrypt.html
ssl_certificate /etc/ssl/certs/iRedMail.crt;
ssl_certificate_key /etc/ssl/private/iRedMail.key;
# configuration file /etc/nginx/templates/iredadmin.tmpl:
# Settings for iRedAdmin.
# static files under /iredadmin/static
location ~ ^/iredadmin/static/(.*) {
alias /opt/www/iredadmin/static/$1;
# Python scripts
location ~ ^/iredadmin(.*) {
rewrite ^/iredadmin(/.*)$ $1 break;
include /etc/nginx/templates/hsts.tmpl;
include uwsgi_params;
uwsgi_pass 127.0.0.1:7791;
uwsgi_param UWSGI_CHDIR /opt/www/iredadmin;
uwsgi_param UWSGI_SCRIPT iredadmin;
uwsgi_param SCRIPT_NAME /iredadmin;
# Access control
#allow 127.0.0.1;
#allow 192.168.1.10;
#allow 192.168.1.0/24;
#deny all;
# iRedAdmin: redirect /iredadmin to /iredadmin/
location = /iredadmin {
rewrite ^ /iredadmin/;
# Handle newsletter-style subscription/unsubscription supported in iRedAdmin-Pro .
location ~ ^/newsletter/ {
rewrite /newsletter/(.*) /iredadmin/newsletter/$1 last;
# configuration file /etc/nginx/templates/hsts.tmpl:
# Use HTTP Strict Transport Security to force client to use secure
# connections only. References:
# * RFC Document (6797): HTTP Strict Transport Security (HSTS)
# https://tools.ietf.org/html/rfc6797#section-6.1.2
# * Short tutorial from Mozilla:
# https://developer.mozilla.org/en-US/docs/Web/Security/HTTP_strict_transport_ security
# WARNING: According to RFC document, HSTS will fail with self-signed SSL
# certificate.
# https://tools.ietf.org/html/rfc6797#page-27
# Syntax:
# Strict-Transport-Security: max-age=expireTime [; includeSubDomains] [; prelo ad]
add_header Strict-Transport-Security "max-age=31536000";
# configuration file /etc/nginx/uwsgi_params:
uwsgi_param QUERY_STRING $query_string;
uwsgi_param REQUEST_METHOD $request_method;
uwsgi_param CONTENT_TYPE $content_type;
uwsgi_param CONTENT_LENGTH $content_length;
uwsgi_param REQUEST_URI $request_uri;
uwsgi_param PATH_INFO $document_uri;
uwsgi_param DOCUMENT_ROOT $document_root;
uwsgi_param SERVER_PROTOCOL $server_protocol;
uwsgi_param REQUEST_SCHEME $scheme;
uwsgi_param HTTPS $https if_not_empty;
uwsgi_param REMOTE_ADDR $remote_addr;
uwsgi_param REMOTE_PORT $remote_port;
uwsgi_param SERVER_PORT $server_port;
uwsgi_param SERVER_NAME $server_name;
# configuration file /etc/nginx/templates/roundcube.tmpl:
# Running Roundcube as a subfolder on an existing virtual host
# Block access to default directories and files under these directories
location ~ ^/mail/(bin|config|installer|logs|SQL|temp|vendor)($|/.*) { deny all; }
# Block access to default files under top-directory and files start with same na me.
location ~ ^/mail/(CHANGELOG|composer.json|INSTALL|jsdeps.json|LICENSE|README|UP GRADING)($|.*) { deny all; }
# Block plugin config files and sample config files.
location ~ ^/mail/plugins/.*/config.inc.php.* { deny all; }
# Block access to plugin data
location ~ ^/mail/plugins/enigma/home($|/.*) { deny all; }
# Redirect URI `/mail` to `/mail/`.
location = /mail {
return 301 /mail/;
location ~ ^/mail/(.*\.php)$ {
include /etc/nginx/templates/fastcgi_php.tmpl;
fastcgi_param SCRIPT_FILENAME /opt/www/roundcubemail/$1;
location ~ ^/mail/(.*) {
alias /opt/www/roundcubemail/$1;
index index.php;
# configuration file /etc/nginx/templates/fastcgi_php.tmpl:
# Template used to handle PHP fastcgi applications
# You still need to define `SCRIPT_FILENAME` for your PHP application, and
# probably `fastcgi_index` if your application use different index file.
include fastcgi_params;
# Directory index file
fastcgi_index index.php;
# Handle PHP files with upstream handler
fastcgi_pass php_workers;
# Fix the HTTPROXY issue.
# Reference: https://httpoxy.org/
fastcgi_param HTTP_PROXY '';
# configuration file /etc/nginx/fastcgi_params:
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT $document_root;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param REQUEST_SCHEME $scheme;
fastcgi_param HTTPS $https if_not_empty;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx/$nginx_version;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param REDIRECT_STATUS 200;
# configuration file /etc/nginx/templates/sogo.tmpl:
# Settings for SOGo Groupware
# SOGo
location ~ ^/sogo { rewrite ^ https://$host/SOGo; }
location ~ ^/SOGO { rewrite ^ https://$host/SOGo; }
# Redirect /mail to /SOGo
#location ~ ^/mail { rewrite ^ https://$host/SOGo; }
# For Mac OS X and iOS devices.
rewrite ^/.well-known/caldav /SOGo/dav permanent;
rewrite ^/.well-known/carddav /SOGo/dav permanent;
rewrite ^/principals /SOGo/dav permanent;
location ^~ /SOGo {
proxy_pass http://127.0.0.1:20000;
# forward user's IP address
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $host;
# always use https
proxy_set_header x-webobjects-server-port $server_port;
proxy_set_header x-webobjects-server-name $host;
proxy_set_header x-webobjects-server-url https://$host;
proxy_set_header x-webobjects-server-protocol HTTP/1.0;
location ^~ /Microsoft-Server-ActiveSync {
proxy_pass http://127.0.0.1:20000/SOGo/Microsoft-Server-ActiveSync;
proxy_connect_timeout 3540;
proxy_send_timeout 3540;
proxy_read_timeout 3540;
location ^~ /SOGo/Microsoft-Server-ActiveSync {
location /SOGo.woa/WebServerResources/ {
alias /usr/lib/GNUstep/SOGo/WebServerResources/;
expires max;
location /SOGo/WebServerResources/ {
expires max;
location ^/SOGo/so/ControlPanel/Products/([^/]*)/Resources/(.*)$ {
alias /usr/lib/GNUstep/SOGo/$1.SOGo/Resources/$2;
expires max;
# configuration file /etc/nginx/templates/netdata.tmpl:
# Running netdata as a subfolder to an existing virtual host
# FYI: https://github.com/firehol/netdata/wiki/Running-behind-nginx
location = /netdata {
return 301 /netdata/;
location ~ /netdata/(?<ndpath>.*) {
proxy_redirect off;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_http_version 1.1;
proxy_pass_request_headers on;
proxy_set_header Connection "keep-alive";
proxy_store off;
proxy_pass http://127.0.0.1:19999/$ndpath$is_args$args;
gzip on;
gzip_proxied any;
gzip_types *;
auth_basic "Authentication Required";
auth_basic_user_file /etc/nginx/netdata.users;
# configuration file /etc/nginx/templates/php-catchall.tmpl:
# Normal PHP scripts
location ~ \.php$ {
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
# configuration file /etc/nginx/templates/stub_status.tmpl:
location = /stub_status {
stub_status on;
access_log off;
allow 127.0.0.1;
deny all;
location = /status {
fastcgi_param SCRIPT_FILENAME $fastcgi_script_name;
access_log off;
allow 127.0.0.1;
deny all;
# configuration file /etc/nginx/templates/icingaweb2.tmpl:
location ~ ^/icingaweb2/index\.php(.*)$ {
fastcgi_pass 127.0.0.1:9000;
fastcgi_param SCRIPT_FILENAME /usr/share/icingaweb2/public/index.php;
fastcgi_param ICINGAWEB_CONFIGDIR /etc/icingaweb2;
fastcgi_param REMOTE_USER $remote_user;
location ~ ^/icingaweb2(.+)? {
alias /usr/share/icingaweb2/public;
index index.php;
try_files $1 $uri $uri/ /icingaweb2/index.php$is_args$args;
# configuration file /etc/nginx/sites-enabled/00-default.conf:
# HTTP
server {
# Listen on ipv4
listen 80;
listen [::]:80;
server_name _;
# Redirect all insecure http:// requests to https://
return 301 https://$host$request_uri;
