I just went through icinga setup yet again, trying to finally finish it, yet it fails this time after setting up the command transport with this error message:
Successfully connected to existing database “icingadb”…
Creating database schema…
Failed to fully setup the database. An error occured:
ERROR: PDOException in /usr/share/icingaweb2/modules/setup/library/Setup/Utils/DbTool.php:477 with message: SQLSTATE[42710]: Duplicate object: 7 ERROR: Type »boolenum« already existsModule “monitoring” has been successfully enabled.
There aren’t any entries in the icingaweb2 logs.
- Icinga Web 2 version: 2.12.1-1+debian12
- Used modules and their versions (System - About): -
- Web browser used: Chrome 125.0.6382.3
- Icinga 2 version used (
icinga2 --version
): r2.14.2-1 - PHP version used (
php --version
): 8.2.7 - Server operating system and version: Debian 12.5
