After upgrade from 15.2 to 15.3 there is is an error on the login page. Seems, during the upgrade PHP was upgraded too. Now Icinga WEB 2 has problem with the ZEND famework.
Copy of the screeen:
Fatal error: Uncaught ErrorException: Uncaught ErrorException: include(): \Icinga\Web\ViewStream::stream_set_option is not implemented! in /usr/share/php/Icinga/Web/View.php:262 Stack trace: #0 /usr/share/php/Icinga/Web/View.php(262): Icinga\Application\ApplicationBootstrap->Icinga\Application{closure}(2, ‘include(): \Ici…’, ‘/usr/share/php/…’, 262, Array) #1 /usr/share/php/Icinga/Web/View.php(262): include() #2 /usr/share/icingaweb2/library/vendor/Zend/View/Abstract.php(877): Icinga\Web\View->_run(’/usr/share/icin…’) #3 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action/Helper/ViewRenderer.php(904): Zend_View_Abstract->render(NULL) #4 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action/Helper/ViewRenderer.php(925): Zend_Controller_Action_Helper_ViewRenderer->renderScript(‘error/error.pht…’, NULL) #5 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action/Helper/ViewRenderer.php(964): Zend_Controller_Action_Helper_ViewRenderer->render() #6 /usr/share/icingaweb2/library/vendor/Zend/Controller in /usr/share/icingaweb2/library/vendor/Zend/Controller/Plugin/Broker.php on line 259 -
The URL: https://packages.icinga.com/openSUSE/15.3/release/ repository doesn’t exist
Hey
We finished building all of the relevant Icinga packages for openSUSE 15.3 and SLES 15.3 as well.
The repository should exist now and you can install Icinga 2 and Icingaweb 2 as you would expect.
Have fun!
Hey, I was just wondering why the SLES 15.3 repository is not available anymore (since 2-3 weeks)?
Do I have to migrate my custom RMT repositories to the one for openSUSE?
Well, it should be up.
We’re checking what’s wrong
Update:
I have no idea why they weren’t up, but this should be fixed today
Edit: It should be available now, if you want to test it
Thank you!
Everything works as expected again.
