We are thinking to upgrade our Icinga infrastructure. Like it is described in the documentation we should maintain components version compatibility.
Short plan can be the following:
- Upgrade all Agents to the 2.9
- Upgrade Master to the 2.11
- Upgrade Satellite to the 2.11
- Upgrade all Agents to the 2.11
And here a question appeared. Which versions of the Agents are installed right now on the hosts.
Is there a way to get such information from the Icinga Web2?
It is some kind of simple inventory - at least:
Host - OS - Agent version
Thank you!
