Icinga Web 2 version: 2.12.0
Used modules and their versions:
Loaded Modules
grafana 2.0.3 Configure
icingadb 1.1.0 Configure
incubator 0.20.0 Configure
vspheredb 1.7.1 Configure -
Web browser used: chrome 117.0.5938.132
Icinga 2 version used (version: r2.14.0-1)
PHP version used (8.0.30)
Server operating system and version: Platform: CentOS Linux
Platform version: 7 (Core)
Kernel version: 3.10.0-1160.99.1.el7.x86_64
Hi guys! I’m trying to set up the vspheredb module, but there is almost no documentation about it (or I’m very bad at searching)
the module is up and running, I can add a vcenter or esx hosts and it can gather all the data , I defined monitoring rules and they also works flawlessly.
Setting up the monitoring integration, as I’m using icingadb, there was no IDO resource, so I activated the monitoring module, created an IDO resource and deactivated the monitoring module again, then I configured the monitoring integration on the vspheredb module and works great! (not very intuitive, but is working now)
I created the check commands and the services to actively monitor vsphere, esx hosts , vms, datastores, etc. everything works as expected, alarms are getting triggered, data is displayed correctly, but there is no way to get perfdata.
the data is been writed to the influxdb, but without perfdata
my influxdb
> SELECT * FROM "icingacli-vspheredb";
time acknowledgement current_attempt downtime_depth execution_time hostname latency max_check_attempts reachable service state state_type
1696468738642856960 0 2 0 0.126118 esx.narf.cl 0.000581 5 true icingacli-vspheredb-datastore-storage1 1 0
1696468767046152192 0 3 0 0.092586 esx.narf.cl 0.00066 5 true icingacli-vspheredb-datastore-storage1 1 0
1696468795482407936 0 4 0 0.125576 esx.narf.cl 0.000637 5 true icingacli-vspheredb-datastore-storage1 1 0
1696468819299655936 0 1 0 0.104623 esx.narf.cl 0.195152 5 true icingacli-vspheredb-datastore-storage1 1 1
check output on the linux console
[root@monitor ~]# icingacli vspheredb check datastore --uuid 3796edf8-0796-51ec-8265-7e22d5503044
[OK] Datastore, according configured rules
[OK] Object State Policy
[OK] Overall VMware Object State
\_ [OK] Overall VMware status is 'green'
[OK] Datastore Health
[OK] Datastore Usage
\_ [OK] 7.18 TiB out of 7.28 TiB (98.73%) free
command definition:
object CheckCommand "icingacli-vspheredb" {
import "plugin-check-command"
command = [ "/usr/bin/icingacli", "vspheredb", "check" ]
timeout = 1m
arguments += {
"(no key)" = {
order = 1
required = true
skip_key = true
value = "$vspheredb_check_mode$"
"--name" = {
order = 2
required = false
value = "$vspheredb_object_name$"
"--uuid" = {
order = 2
required = false
value = "$vspheredb_object_uuid$"
"--perfdata" = {
order = 3
required = false
set_if = "$vspheredb_perfdata$"
service definition:
apply Service "icingacli-vspheredb-datastore-" for (datastores => config in host.vars.vspheredb_datastore) {
import "generic-service"
display_name = "WMware DataStore " + datastores
check_command = "icingacli-vspheredb"
vars.vspheredb_check_mode = "datastore"
vars.vspheredb_perfdata = true
vars += config
notes= "Chequeo de datastores vmware" + vars.vspheredb_object_label
assign where host.vars.vspheredb_datastore
apply Service "icingacli-vspheredb-esx-host" {
display_name = "WMware ESX "
vars.vspheredb_check_mode = "host"
notes= "Chequeo de host ESX"
assign where host.vars.vspheredb_esx_host
apply Service "icingacli-vspheredb-vm" {
display_name = "WMware VM "
vars.vspheredb_check_mode = "vm"
notes= "Chequeo de Virtual Machine"
assign where host.vars.vspheredb_vm
host config file:
object Host "esx.narf.cl" {
display_name = "Esx OrangeBox"
import "generic-host"
enable_flapping = true
address = "192.100.200.145"
vars.os = "vmware_esx"
groups = ["vmware_esx"]
vars.notification["mail"] = {
groups = [ "icingaadmins" ]
#check ping
vars.check_ping = true
vars.vspheredb_esx_host = true
vars.vspheredb_object_name = "$host.name$"
#VMWare DataStore
vars.vspheredb_datastore["storage1"] = {
vspheredb_object_uuid = "3796edf8-0796-51ec-8265-7e22d5503044"
vspheredb_perfdata = "true"
#VMWare DataStore
vars.vspheredb_datastore["cache"] = {
vspheredb_object_uuid = "ae5d0495-3fa3-599f-a30c-b8f330422c58"
monitoring integration:
esx output (no data to graph)
help output of the icingacli vsphere module (there is no perfdata option)
[root@monitor ~]# icingacli help vspheredb check datastore
Check Datastore Health
USAGE
icingacli vspheredb check datastore [--name <name>|--uuid <uuid>] [--ruleset <set>] [--rule [<ruleset>/]<rule>]
[root@monitoreo ~]# icingacli help vspheredb perf
Deprecated. The main daemon now provides this functionality
where? how? is there is anyway to get perfdata from this module? it’s a wonderful module, works pretty well, but without perfdata is pretty useless to me ![]()
