all Icinga Vagrant Boxes don’t work for me. I use these components:
macOS Big Sur 11.2.3
Parallels Desktop Pro 16 for Mac 16.1.3
Vagrant 2.2.15
Vagrant Parallels Plugin 2.2.0
And this is the error log:
username@macbook graylog % vagrant up
Bringing machine ‘icinga2-graylog’ up with ‘parallels’ provider…
==> icinga2-graylog: Registering VM image from the base box ‘bento/centos-7’…
==> icinga2-graylog: Creating new virtual machine as a linked clone of the box image…
==> icinga2-graylog: Unregistering the box VM image…
==> icinga2-graylog: Setting the default configuration for VM…
==> icinga2-graylog: Checking if box ‘bento/centos-7’ version ‘202103.18.0’ is up to date…
==> icinga2-graylog: Setting the name of the VM: Icinga 2: icinga2-graylog
==> icinga2-graylog: Preparing network interfaces based on configuration…
icinga2-graylog: Adapter 0: shared
icinga2-graylog: Adapter 1: hostonly
==> icinga2-graylog: Clearing any previously set network interfaces…
==> icinga2-graylog: Forwarding ports…
icinga2-graylog: 443 => 6443
icinga2-graylog: 80 => 6082
icinga2-graylog: 22 => 2086
icinga2-graylog: 9000 => 9000
icinga2-graylog: 12201 => 12201
==> icinga2-graylog: Running ‘pre-boot’ VM customizations…
==> icinga2-graylog: Booting VM…
==> icinga2-graylog: Waiting for machine to boot. This may take a few minutes…
icinga2-graylog: SSH address: 10.211.55.14:22
icinga2-graylog: SSH username: vagrant
icinga2-graylog: SSH auth method: private key
icinga2-graylog:
icinga2-graylog: Vagrant insecure key detected. Vagrant will automatically replace
icinga2-graylog: this with a newly generated keypair for better security.
icinga2-graylog:
icinga2-graylog: Inserting generated public key within guest…
icinga2-graylog: Removing insecure key from the guest if it’s present…
icinga2-graylog: Key inserted! Disconnecting and reconnecting using new SSH key…
==> icinga2-graylog: Machine booted and ready!
==> icinga2-graylog: Checking for Parallels Tools installed on the VM…
==> icinga2-graylog: Parallels Tools installed on this VM are outdated! In most cases
==> icinga2-graylog: this is fine but in rare cases it can cause things such as shared
==> icinga2-graylog: folders to not work properly. If you see shared folder errors,
==> icinga2-graylog: please update Parallels Tools within the virtual machine and
==> icinga2-graylog: reload your VM.
==> icinga2-graylog: Setting hostname…
==> icinga2-graylog: Configuring and enabling network interfaces…
==> icinga2-graylog: Mounting shared folders…
icinga2-graylog: /vagrant => /Users/username/icinga-vagrant/graylog
icinga2-graylog: /hieradata => /Users/username/icinga-vagrant/.puppet/hieradata
icinga2-graylog: /tmp/vagrant-puppet/environments => /Users/username/icinga-vagrant/graylog/environments
icinga2-graylog: /tmp/vagrant-puppet/modules-151d8d7949fd7ce0eab31fd3e06efb36 => /Users/username/icinga-vagrant/.puppet/modules
==> icinga2-graylog: Forcing shutdown of VM…
==> icinga2-graylog: Clearing any previously set forwarded ports…
==> icinga2-graylog: Destroying VM and associated drives…
==> icinga2-graylog: Destroying unused networking interface…
Traceback (most recent call last):
110: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/batch_action.rb:86:in block (2 levels) in run' 109: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/machine.rb:201:in action’
108: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/machine.rb:201:in call' 107: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/environment.rb:614:in lock’
106: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/machine.rb:215:in block in action' 105: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/machine.rb:246:in action_raw’
104: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in run' 103: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/util/busy.rb:19:in busy’
102: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in block in run' 101: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builder.rb:149:in call’
100: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 99: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/call.rb:53:in call’
98: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in run' 97: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/util/busy.rb:19:in busy’
96: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in block in run' 95: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builder.rb:149:in call’
94: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 93: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
92: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 91: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/handle_box.rb:56:in call’
90: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 89: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
88: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 87: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/config_validate.rb:25:in call’
86: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 85: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/call.rb:53:in call’
84: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in run' 83: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/util/busy.rb:19:in busy’
82: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in block in run' 81: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builder.rb:149:in call’
80: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 79: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
78: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 77: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/customize.rb:39:in call’
76: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 75: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/box_register.rb:36:in call’
74: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 73: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/prepare_clone.rb:15:in call’
72: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 71: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/prepare_clone_snapshot.rb:36:in call’
70: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 69: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/import.rb:66:in call’
68: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 67: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/box_unregister.rb:32:in call’
66: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 65: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/sane_defaults.rb:24:in call’
64: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 63: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/customize.rb:39:in call’
62: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 61: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
60: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 59: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/box_check_outdated.rb:93:in call’
58: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 57: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/call.rb:53:in call’
56: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in run' 55: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/util/busy.rb:19:in busy’
54: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in block in run' 53: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builder.rb:149:in call’
52: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 51: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
50: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 49: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/call.rb:53:in call’
48: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in run' 47: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/util/busy.rb:19:in busy’
46: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in block in run' 45: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builder.rb:149:in call’
44: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 43: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
42: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 41: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/call.rb:53:in call’
40: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in run' 39: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/util/busy.rb:19:in busy’
38: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/runner.rb:89:in block in run' 37: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builder.rb:149:in call’
36: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 35: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:127:in block in finalize_action’
34: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 33: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/check_shared_interface.rb:13:in call’
32: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 31: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/set_name.rb:48:in call’
30: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 29: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/clear_forwarded_ports.rb:16:in call’
28: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 27: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/provision.rb:80:in call’
26: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 25: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/prepare_forwarded_port_collision_params.rb:35:in call’
24: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 23: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/handle_forwarded_port_collisions.rb:52:in call’
22: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 21: from /Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/action/prepare_nfs_valid_ids.rb:12:in call’
20: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 19: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/synced_folders/nfs/action_cleanup.rb:25:in call’
18: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 17: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/synced_folder_cleanup.rb:28:in call’
16: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 15: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/delayed.rb:19:in call’
14: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/warden.rb:48:in call' 13: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/action/builtin/synced_folders.rb:145:in call’
12: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/guest.rb:43:in capability' 11: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/capability_host.rb:111:in capability’
10: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/capability_host.rb:111:in call' 9: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:27:in persist_mount_shared_folder’
8: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:27:in map' 7: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:27:in each’
6: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:28:in block in persist_mount_shared_folder' 5: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:28:in map’
4: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:28:in each' 3: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/plugins/guests/linux/cap/persist_mount_shared_folder.rb:37:in block (2 levels) in persist_mount_shared_folder’
2: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/capability_host.rb:111:in capability' 1: from /opt/vagrant/embedded/gems/2.2.15/gems/vagrant-2.2.15/lib/vagrant/capability_host.rb:111:in call’
/Users/username/.vagrant.d/gems/2.6.6/gems/vagrant-parallels-2.2.0/lib/vagrant-parallels/cap/mount_options.rb:33:in `mount_name’: wrong number of arguments (given 3, expected 2) (ArgumentError)
So, there are too many arguments.
Does anyone know this error and can help me?
Regards
Olaf
