I am prince from Ghana. I use icinga version 2.8.2, and almost a week now anytime i restart “icinga2.service” in my terminal it takes to long to reply back.
And also anytime i open my icingaweb2 and i try to open a service or host in the dashboard it loads nothing and there’s no information shown as well, this also happened this week.
Find attached a screen shot on the icingaweb2 panel with the red circled side showing nothing loading.
Thanks for the reply.
can you teach me how to upgrade my version of icinga to the current one please cos am new to this.
Centos on a virtual machine
16gb Ram
the load average i get is 0.30,0.14,0.12
i just monitor websites via ping , at the moment i have added only 3 websites to monitor. i used director
5.1 only ping
okay so i have been trying to add graphite this week. did the graphite installation on another server and pasted the link on my icingaweb2 graphite backend but still shows no graphs found.
and also this week i tried to add the mapdatatype too but am not seeing anything as well.
I can’t answer that because I’m not familiar with CentOS, however:
There’s nothing different about upgrading Icinga from upgrading any other
application
There are other people here who are familiar with CentOS and I’m sure can
answer your question in more detail.
16gb Ram
That’s quite a big VM - is it doing anything else than running Icinga?
So, nothing significant for Icinga to do, then.
i used director
Okay, that’s significant - I don’t use Director, so if there’s anything specific
to the way that sets up the machine, someone else can answer better than I
can.
1 only ping
Okay, so that’s basically nothing as far as Icinga is concerned (especially
with 16 Gb RAM).
Did that one work?
graphs found. and also this week i tried to add the mapdatatype too but am
Let’s deal with one problem at a time before making things any more complex.
Did your problem with Icinga exist before you added Graphite?
Also, what you see in /var/log/icinga2/icinga2.log when you restart Icinga and
it takes a long time?
I was able to fix it. the problem was with my graphite, i had to disable it then it icinga started to work normal again . But i till want to use graphite.
Any help
