Icinga Reporting: "array_map(): Argument #2 should be an array" error after I change module's resource
As I’ve mentioned in the topic, I have problem with error “array_map(): Argument #2 should be an array” after I changed Icinga Reporting module’s resource to correct one.
I have installed all dependencies for Reporting which are: ipl, reactbundle, pdfexport.
I am clueless as I have no experience with code like that shown below on the screenshot.
My Icinga Web 2 version is 2.7.3 and it’s my testing VM with OS Ubuntu 20.04.1 LTS.
please show the contents of the file /etc/icingaweb2/modules/reporting/reporting.ini
There seems to be something wrong with this file.
Unfortunately I can’t find reporting.ini in /etc/icingaweb2/modules/reporting.
problem1
Well, that might be the problem. :smiley:
You’ve installed the module incorrectly. /etc/icingaweb2/modules is for the configuration of modules, not the modules themselves. Put the module somewhere else, preferably where Icinga Web 2 is installed. That’s usually /usr/share/icingaweb2/modules, if it’s been installed by a package.
It works now!
Sorry for my (as it seems for me) rookie mistake.
Thank you for your help! I wouldn’t solve it by myself.
Don’t worry about making “rookie mistakes” too much, I’ve been working with Icinga for 4 years now and I still sometimes mix stuff like this up :slight_smile:
We can’t know everything!
