Icinga Powershell Module Offline Mode Install
Hello
:slight_smile: After some push and nudge by @cstein want to explore the powershell module and move away from nsclient. We already have puppet and sccm method to install and configure agent. I do not want to touch those and just install the powershell module alone without installing / reinstalling the agent.
Also we need to install it in offline mode.
[Net.ServicePointManager]::SecurityProtocol = "tls12, tls11";
$ProgressPreference = "SilentlyContinue";
$global:IcingaFrameworkKickstartSource = 'C:\iCinga\icinga-powershell-kickstart.psi';
$Script = (Invoke-WebRequest -UseBasicParsing -Uri $global:IcingaFrameworkKickstartSource).Content;
$Script += "`r`n`r`n Start-IcingaFrameworkWizard;";
Invoke-Command -ScriptBlock ([Scriptblock]::Create($Script));
And boom error error error :slight_smile: Obviously I did I mistake.
Exception calling "Create" with "1" argument(s): "At line:1 char:5
+ 102 117 110 99 116 105 111 110 32 83 116 97 114 116 45 73 99 105 110  ...
Unexpected token '117' in expression or statement.
At line:1 char:9
Unexpected token '110' in expression or statement.
At line:1 char:13
Unexpected token '99' in expression or statement.
At line:1 char:16
Unexpected token '116' in expression or statement.
At line:1 char:20
Unexpected token '105' in expression or statement.
At line:1 char:24
Unexpected token '111' in expression or statement.
At line:1 char:28
At line:1 char:32
Unexpected token '32' in expression or statement.
At line:1 char:35
Unexpected token '83' in expression or statement.
At line:1 char:38
Not all parse errors were reported.  Correct the reported errors and try again."
At line:1 char:1
+ Invoke-Command -ScriptBlock ([Scriptblock]::Create($Script));
    + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : ParseException
Hello there!
@cstein is the right person to bug about this actually :slight_smile:
I will ask him to have a look at this later, maybe we can figure it out together :wink:
Have a nice week,
Feu
the issue here is that local files are read as “binary” content and not text by using Invoke-WebRequest.
To resolve this, either use Get-Content instead of Invoke-WebRequest or convert the byte array to string first:
$Script = [System.Text.Encoding]::UTF8.GetString($Script);
I hope this helps!
