Hi, that’s work for Monday. I do it once again, the last time I used Uninstall-IcingaForWindows;, and checked all the folders you mentioned.
The call of Invoke-IcingaCheckUsedPartitionSpace takes 45 seconds. The error message repeats 14 times, exactly the number of virtual disks of the big RAID. See the full error file.
The NULL-Array error is on every server, virtual and bare metal, even on fresh installs without any Icinga installation before.
Complete stderr/stdout
Es ist nicht möglich, einen Index auf ein NULL-Array anzuwenden.
In C:\Program
Files\WindowsPowerShell\Modules\icinga-powershell-plugins\provider\disks\Get-IcingaPhysicalDiskInfo.psm1:122 Zeichen:17
+ $DiskInfo.BusType = @{
+ CategoryInfo : InvalidOperation: (:) [], RuntimeException
+ FullyQualifiedErrorId : NullArray
In C:\Program
Files\WindowsPowerShell\Modules\icinga-powershell-plugins\provider\disks\Get-IcingaPhysicalDiskInfo.psm1:130 Zeichen:25
+ ... Add-IcingaHashtableItem -Hashtable $OperationalStatus -Ke ...
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
In C:\Program
[UNKNOWN]: Icinga Invalid Input Error was thrown: ConversionUnitMissing
Unable to parse input value. You have to add an unit to your input value. Example: "10GB". Allowed units are: "B, KB,
MB, GB, TB, PB, KiB, MiB, GiB, TiB, PiB".
Ausnahme beim Aufrufen von "WarnOutOfRange" mit 1 Argument(en): "Systemfehler"
In C:\Program
Files\WindowsPowerShell\Modules\icinga-powershell-plugins\plugins\Invoke-IcingaCheckUsedPartitionSpace.psm1:144
Zeichen:17
+ ... $IcingaCheck.WarnOutOfRange($Warning).CritOutOfRange($Cri ...
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : ScriptMethodFlowControlException
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
In C:\Program
Zeichen:17
Ausnahme beim Aufrufen von "Compile" mit 0 Argument(en): "Ausnahme beim Aufrufen von "Compile" mit 0 Argument(en):
"Ausnahme beim Aufrufen von "Compile" mit 0 Argument(en): "Ausnahme beim Aufrufen von
"__CreateDefaultThresholdObject" mit 0 Argument(en): "Systemfehler""""
In C:\Program Files\WindowsPowerShell\Modules\icinga-powershell-framework\cache\framework_cache.psm1:23124 Zeichen:16
+ return $IcingaCheckResult.Compile();
+ FullyQualifiedErrorId : ScriptMethodRuntimeException
Check
@{Name=Used Partition Space; Verbose=0; __CheckPerfData=System.Collections.Hashtable; __Hidden=False; __Parent=; __I...
