I’m getting stuck installing on the PI…
root@Office-pi:~# apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@Office-pi:~# sudo apt install icinga2 icingaweb2
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
icinga2 : Depends: icinga2-bin (= 2.10.4-1.stretch) but it is not going to be installed
icingaweb2 : Depends: icingaweb2-common (= 2.6.2-1.stretch) but it is not going to be installed
Depends: php-xml but it is not installable
Recommends: apache2 but it is not going to be installed or
httpd
Recommends: php but it is not installable
Recommends: php-cli but it is not installable
Recommends: php-curl but it is not installable
Recommends: php-ldap but it is not installable
Recommends: php-json but it is not installable
Recommends: php-intl but it is not installable
Recommends: php-imagick but it is not installable
Recommends: icingacli but it is not going to be installed
Recommends: icingaweb2-module-monitoring but it is not going to be installed
Recommends: icingaweb2-module-doc but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@Office-pi:~# uname -a
Linux Office-pi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
root@Office-pi:~# cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="EMPTY due to forum restrictions for new persons/"
SUPPORT_URL="EMPTY due to forum restrictions for new persons/"
BUG_REPORT_URL="EMPTY due to forum restrictions for new persons/"
