Icinga not sending HOST metadata to carbon/graphite
I have a running & working configuration using graphite to render and graph my data. I’ve recently modified the file: /etc/icinga2/features-enabled/graphite.conf adding the next line:
enable_send_metadata = true.
I’ve restarted the service and it actually started sending SERVICES’ metadata. My problem is as follows:
It is NOT sending HOST metadata, i.e. .[...].hostalive.metadata.* does NOT exists on graphite.
@htriem Don’t you have a such setup up and running? Please verify this problem.
EDIT: Unkown bug, just kept reloading all daemons [icinga2, carbon-cache ] and started sending it.
Hello there,
thank you for the update on this!
If you think you found a bug, would you be so kind to open a bug report on GitHub? :slight_smile:
This is where our developers check in a lot more regularly, as it’s a lot more ingrained into their workflow :slight_smile:
Thank you very much!
Feu
