Icinga map module ICMP only
I’m trying to set up a icmp only map using icinga2 map module. I already had defined hosts and services which appear on map. Nonetheless as early as a service is down; host state on the map switches to red, even if ping is good. I would like to keep my services and hosts on map but only make the state switch to red if ping is lost (hence ICMP only). is there any option to do so & to ignore service state specificaly in the map module ?
Axel
