My servers dont have access to the web and i chose in self service API settings to install agent from local network. The path and everything is there, i regenerated the selfservice API key but when i run it, it again tries to download the agent from the web… Im using the kickstart script from the Agent tab in host template
Do you know how i can control this? I have the installation on a network drive and all it needs is to either install it from there or dont install it at all. Possilby i run the SCCM first to install agent.msi, for kickstart script to only configure it later for me.
[Error]: Unable to load the Icinga PowerShell Framework. Please check your PowerShell execution policies for possible problems. Error: System.Management.Automation.CommandNotFoundException: Th
e term 'Use-Icinga' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path
is correct and try again.
at System.Management.Automation.ExceptionHandlingOps.CheckActionPreference(FunctionContext funcContext, Exception exception)
at System.Management.Automation.Interpreter.ActionCallInstruction`2.Run(InterpretedFrame frame)
at System.Management.Automation.Interpreter.EnterTryCatchFinallyInstruction.Run(InterpretedFrame frame)
Hello again, im really sorry but this whole thing is a mess and i cannot make it work.
Now im having an issue syncing the repo to the local PC. It starts, gets to 17% progress, then powershell just closes and no files get written to local folder.
