Introduce an automatic/interactive installer for the entire Icinga stack. (GitHub - NETWAYS/icinga-installer: An easy to use Icinga-Installer)
Release 1.0.0 with IcingaDB support is out now.
Since version 1.2.0 the Installer can now be used completely for management purposes.
“Since version 1.2.0 the Installer can now be used completely for management
purposes.”
Please can you explain that comment a bit more? It sounds intriguing, but I’m
not entirely sure what it means we can now do.
Antony.
Sorry. This means you can now use the installer completely to reconfigure your environment. Until now it was the case that roles (roles.ini) were completely overwritten during an Installer rerun. Now this file is created only initially, so that the default admin can log in.
Additional resources, e.g. for import source of the director, can now also be managed sustainably via the custom-hiera.yaml file. The same applies to the user and group access rules.
Here you can find documentation including examples:
