Icinga / Icinga Web2 Installation on CentOS 7
Hello, I’m completely lost trying to install onto a CentOS 7 box. I’ve followed the various installation pages as best as I can but I’m still gettting page not found on browsing to /icinga/setup
I’ve kept a log of the various commands/steps I ran as I followed the guides, any help greatlky appreciated
System cleanly installed and yum -y updates run.
Linux bhmmonmas01.mydomain.local 3.10.0-957.10.1.el7.x86_64 #1 SMP Mon Mar 18 15:06:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
yum -y install https://packages.icinga.com/epel/icinga-rpm-release-7-latest.noarch.rpm
yum -y install epel-release
yum -y install icinga2
systemctl enable icinga2
systemctl start icinga2
icinga2 feature list
Disabled features: api command compatlog debuglog elasticsearch gelf graphite influxdb livestatus opentsdb perfdata statusdata syslog
Enabled features: checker mainlog notification
yum -y install nagios-plugins-all
yum -y install icinga2-selinux
yum -y install vim-icinga2
Setting up Icinga Web 2
yum -y install mariadb-server mariadb
systemctl enable mariadb
systemctl start mariadb
mysql_secure_installation
yum -y install icinga2-ido-mysql
Set up a MySQL database for Icinga 2:
mysql -u root -p
CREATE DATABASE icinga;
GRANT SELECT, INSERT, UPDATE, DELETE, DROP, CREATE VIEW, INDEX, EXECUTE ON icinga.* TO ‘icinga’@‘localhost’ IDENTIFIED BY ‘icinga’;
quit
icinga2 feature enable ido-mysql
systemctl restart icinga2
yum -y install httpd
firewall-cmd --add-service=http
firewall-cmd --permanent --add-service=http
systemctl enable httpd
systemctl start httpd
Icinga Web 2 install
yum install https://packages.icinga.com/epel/icinga-rpm-release-7-latest.noarch.rpm
yum install epel-release
yum install centos-release-scl
yum install icingaweb2 icingacli icingaweb2-selinux
yum install httpd
systemctl start httpd.service
systemctl enable httpd.service
systemctl start rh-php71-php-fpm.service
systemctl enable rh-php71-php-fpm.service
yum install rh-php71-php-mysqlnd
What I had to do on CentOS installs was setting up some firewall rules.
I will just copy the whole block of rules I am enabling.
firewall-cmd --zone=public --permanent --add-port=80/tcp
firewall-cmd --zone=public --permanent --add-port=5665/tcp
firewall-cmd --zone=public --permanent --add-port=5666/tcp
firewall-cmd --permanent --add-service=smtp
firewall-cmd --permanent --add-service=submission
firewall-cmd --permanent --add-service=smtps
firewall-cmd --permanent --add-port=25/tcp
firewall-cmd --reload
setsebool -P httpd_can_network_connect 1
setsebool -P httpd_can_network_connect_db 1
Hope this helps.
Also maybe check if disabling SELinux (temporarily) helps, and maybe define some additional rules for it. Can’t really help you there though, I’m afraid
The default is /icingaweb2/setup if you didn’t modify the apache configuration provided by the packages.
Setting SELinux to permissive if you lack experience with Icinga but the packages should provide all you need for Icinga to run on an SELinux-enabled system.
Same goes for the firewall. You might want to deactivate firewalld while you’re still learning and testing but with the rules @log1c showed above it should work. I would add port 443/tcp and remove the smtp ports, though.
Remember that there’s a SELinux boolean for MySQL/MariaDB connection via network, too if you want to connect via port not localhost.
BTW: Welcome to the community, @mattb
