Hello all,
another Question from me ![]()
I build a new Icinga 2 Setup, with two Masters, a seperated Icingaweb2 Installation (with Director) and a seperated MySQL-Database. There´s also one Satellite at the Moment, connected to both Masters.
The Config Master is Master-1, which receives the Deployments from the Director.
Now my Problem: If i stop the icinga service on the Master-1, i can´t reschedule Checks.
Error: icinga2: Failed to connect to icinga2-primary port 5665: Connection refused.
That´s fine so far, but shouldn´t run icinga the checks on the secondary node? The Failover is working, the Active Endpoint is the Master-2 Node. Also the checks are automatically executed after 5 min e.g… But the rescheduling is not working.
If you need more information, please just let me know.
Thanks for the help in advance.
System: Debian11
Icinga Version: Version: r2.13.3-1
Enabled Features (Master-1 and 2): api checker ido-mysql mainlog notification
icinga2 object list --type Zone looks the Same on Master-1 (Primary) and Master-2 (Secondary):
root@icinga2-primary:/usr/lib/nagios/plugins# icinga2 object list --type Zone
Object 'director-global' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 20:1-20:29
* __name = "director-global"
* endpoints = null
* global = true
% = modified in '/etc/icinga2/zones.conf', lines 21:2-21:14
* name = "director-global"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 20
* last_column = 29
* last_line = 20
* path = "/etc/icinga2/zones.conf"
* templates = [ "director-global" ]
% = modified in '/etc/icinga2/zones.conf', lines 20:1-20:29
* type = "Zone"
* zone = ""
Object 'master' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 12:1-12:20
* __name = "master"
* endpoints = [ "icinga2-primary.*.de", "icinga2-secondary.*.de" ]
% = modified in '/etc/icinga2/zones.conf', lines 13:2-13:87
* global = false
* name = "master"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 12
* last_column = 20
* last_line = 12
* templates = [ "master" ]
% = modified in '/etc/icinga2/zones.conf', lines 12:1-12:20
* type = "Zone"
* zone = ""
Object 'global-templates' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 16:1-16:30
* __name = "global-templates"
* endpoints = null
* global = true
% = modified in '/etc/icinga2/zones.conf', lines 17:2-17:14
* name = "global-templates"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 16
* last_column = 30
* last_line = 16
* templates = [ "global-templates" ]
% = modified in '/etc/icinga2/zones.conf', lines 16:1-16:30
* type = "Zone"
* zone = ""
Object 'satellite.*.de' of type 'Zone':
% declared in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_zones.conf', lines 1:0-1:38
* __name = "satellite.*.de"
* endpoints = [ "satellite.*.de" ]
% = modified in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_zones.conf', lines 3:5-3:47
* global = false
* name = "satellite.*.de"
* package = "director"
* parent = "master"
% = modified in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_zones.conf', lines 2:5-2:21
* source_location
* first_column = 0
* first_line = 1
* last_column = 38
* last_line = 1
* path = "/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_zones.conf"
* templates = [ "satellite.*.de" ]
% = modified in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_zones.conf', lines 1:0-1:38
* type = "Zone"
* zone = "master"
root@icinga2-primary:/usr/lib/nagios/plugins# icinga2 object list --type Endpoint
Object 'icinga2-secondary.*.de' of type 'Endpoint':
% declared in '/etc/icinga2/zones.conf', lines 9:1-9:51
* __name = "icinga2-secondary.*.de"
* host = "192.168.179.13"
% = modified in '/etc/icinga2/zones.conf', lines 10:2-10:24
* log_duration = 86400
* name = "icinga2-secondary.*.de"
* package = "_etc"
* port = "5665"
* source_location
* first_column = 1
* first_line = 9
* last_column = 51
* last_line = 9
* templates = [ "icinga2-secondary.*.de" ]
% = modified in '/etc/icinga2/zones.conf', lines 9:1-9:51
* type = "Endpoint"
* zone = ""
Object 'satellite.*.de' of type 'Endpoint':
% declared in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_endpoints.conf', lines 1:0-1:42
* host = "192.168.179.16"
% = modified in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_endpoints.conf', lines 2:5-2:27
* log_duration = 0
% = modified in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_endpoints.conf', lines 3:5-3:21
* port = "5665"
* source_location
* first_column = 0
* first_line = 1
* last_column = 42
* last_line = 1
* path = "/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_endpoints.conf"
% = modified in '/var/lib/icinga2/api/packages/director/0ea8d93c-811d-4612-ad3f-e4f0c99f3728/zones.d/master/agent_endpoints.conf', lines 1:0-1:42
* type = "Endpoint"
* zone = "master"
Object 'icinga2-primary.*.de' of type 'Endpoint':
% declared in '/etc/icinga2/zones.conf', lines 6:1-6:49
* __name = "icinga2-primary.*.de"
* host = ""
* name = "icinga2-primary.*.de"
* package = "_etc"
* port = "5665"
* source_location
* first_column = 1
* first_line = 6
* last_column = 49
* last_line = 6
* templates = [ "icinga2-primary.*.de" ]
% = modified in '/etc/icinga2/zones.conf', lines 6:1-6:49
* type = "Endpoint"
* zone = ""
