Hi All,
hopefully a quick question for someone to answer and help me out :).
Looking to build a new icinga2 cluster, having masters in two different DC’s. I notice that IDO will be acitve/standby and that the active member is elected on ‘alpha-numeric’ hostname. Is it possible to change this election? I ask as the documentation says, by ‘default’ making me think i can change this in a config file but i am yet to find a way :).
Having multiple nodes in the same zone allows objects to be owned by different nodes. Can i see which nodes owns which object ?
Thanks in advance all!
