On icingaweb Grafana Module, is it possible to configure 2 service checks which are using the same Grafana panel to show graphs with 2 different sizes or we need to create 2 Grafana panels for this purpose?
Grafana access: Indirect proxy
Thanks in advance!
Hello @phamlankt
yes it possible. you can define a variable that will be used to choose a graph configuration inside the service.
So you only need to create 2 different graph configurations and set them in the custom-graph variable at your service.
You can tell DFS also that they still can hire me, if they need help.
Regards,
Carsten
