Hello.
We are trying to use the executable file of the plugin centreon_plugins.exe (Release Centreon Plugins Release 20240711 · centreon/centreon-nsclient-build · GitHub) on Windows Server 2022 together with the Icinga 2 for Windows agent.
And we have a problem with this.
If we manually run cmd.exe as administrator and execute the command to call centreon_plugins.exe there, it works successfully:
C:\ProgramData\icinga2\plugins\centreon_plugins\centreon_plugins.exe --plugin os::windows::local::plugin --mode pending-reboot
OK: 'Microsoft Windows Server 2022 Standard': reboot pending is false [Windows Update: false][Component Based Servicing: false][SCCM Client: false][File Rename Operations: false][Computer Name Change: false]
The Icinga 2 for Windows agent service runs on behalf of Local System. Therefore, we try to run cmd.exe on behalf of Local System and execute the same command there. And it works successfully again.
But if we try to call the plugin via the Icinga 2 for Windows agent, we get the message “UNKNOWN: Internal error: execution issue: Access is denied”
Please tell us how to debug this situation. We do not understand where the problem with the lack of rights occurs, because the Icinga 2 for Windows agent service runs with full rights, which means the plugin is called with full rights.
Environment configuration:
- Icinga for Windows output (
Show-Icinga) - Operating System and version
Icinga for Windows environment:
PowerShell Root => C:\Program Files\WindowsPowerShell\Modules
Icinga for Windows Service Path => C:\Program Files\icinga-framework-service
Icinga for Windows Service User => LocalSystem
Icinga for Windows Service Pid => 19740
Icinga for Windows JEA Pid =>
Icinga Agent Path => C:\Program Files\ICINGA2
Icinga Agent User => NT Authority\SYSTEM
Defined Default User =>
Icinga Managed User => False
PowerShell Version => 5.1.20348.2400
Operating System => Microsoft Windows Server 2022 Standard
Operating System Version => 10.0.20348
JEA Context =>
JEA Session File =>
Api Check Forwarder => True
Debug Mode => False
Icinga for Windows Certificate:
Issuer => CN=Icinga CA
Subject => CN=backup10.holding.com
List of configured background daemons on this system:
Start-IcingaWindowsRESTApi
No arguments defined
List of configured background service checks on this system:
No background service checks configured
List of configured repositories on this system. The list order matches the apply order:
No repositories configured
Installed components on this system:
Component Version Available
agent 2.14.2
framework 1.12.3
plugins 1.12.0
service 1.2.0
Available versions flagged with “*” mean that this component is locked to this version
- Version used (
icinga2 --version)
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.2-1)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Debian GNU/Linux
Platform version: 12 (bookworm)
Kernel: Linux
Kernel version: 6.1.0-23-amd64
Architecture: x86_64
Build information:
Compiler: GNU 12.2.0
OpenSSL version: OpenSSL 3.0.13 30 Jan 2024
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Enabled features (
icinga2 feature list)
Disabled features: command compatlog debuglog elasticsearch gelf graphite influxdb journald livestatus opentsdb perfdata syslog
Enabled features: api checker icingadb influxdb2 mainlog notification
- Icinga Web 2 version and modules (System - About)
Icinga Web 2 Version 2.12.1
Git commit cd2daeb2cb8537c633d343a29eb76c54cd2ebbf2
PHP Version 8.2.20
Git commit date 2023-11-15
Loaded Libraries
icinga/icinga-php-library 0.14.0
icinga/icinga-php-thirdparty 0.12.1
Loaded Modules
director 1.11.1
grafana 2.0.3
icingadb 1.1.2
incubator 0.22.0
x509 1.3.2
- Config validation (
icinga2 daemon -C)
[2024-08-01 10:49:38 +0300] information/cli: Icinga application loader (version: r2.14.2-1)
[2024-08-01 10:49:38 +0300] information/cli: Loading configuration file(s).
[2024-08-01 10:49:39 +0300] information/ConfigItem: Committing config item(s).
[2024-08-01 10:49:39 +0300] information/ApiListener: My API identity: MON01.holding.com
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 6 NotificationCommands.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 14088 Notifications.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 IcingaApplication.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 21 HostGroups.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 557 Hosts.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 44 Downtimes.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 Influxdb2Writer.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 4 Comments.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 IcingaDB.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 FileLogger.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 143 Zones.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 CheckerComponent.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 33 Users.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 141 Endpoints.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 3 ApiUsers.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 ApiListener.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 NotificationComponent.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 470 CheckCommands.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 UserGroup.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 2 ServiceGroups.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 1 TimePeriod.
[2024-08-01 10:49:42 +0300] information/ConfigItem: Instantiated 5368 Services.
[2024-08-01 10:49:42 +0300] information/ScriptGlobal: Dumping variables to file ‘/var/cache/icinga2/icinga2.vars’
[2024-08-01 10:49:42 +0300] information/cli: Finished validating the configuration file(s).
