Icinga for Kubernetes Web - Cluster views
Hello everyone,
I am testing the Icinga for Kubernetes module and I am a bit puzzled. There seems to be no way to view the deployed clusters, and hierarchically drill down in each cluster, or filter the display per cluster.
We are running two TKGI foundations, each hosting dozens of clusters. When looking at Icinga for Kubernetes, all objects (Nodes, Namespaces, Pods, etc.) are listed for all clusters, resulting in very long lists with lots of duplicates (as many “standard” services are deployed in all clusters).
Is there an easy way for the user to select a cluster and look at the objects within that cluster?
Thank you,
Jean
Hello Jean,
I’m sorry for the late answer. You can select the cluster on the Icinga for Kubernetes Web starting page. Just click at the “Kubernetes” tab in the left sidebar. Then you will find a select element at the top of the page where you can choose your cluster.
Best regards,
Johannes
Thank you Johannes - btw I had found this in the meantime :wink:
But it would be nice to have a filter everywhere in the module and be able to select one or several clusters for which the information needs to be displayed.
Thank you for the feedback!
