Hello everyone,
I’m trying to install Icinga for Kubernetes (0.2.0) and have taken two different approaches.
The first approach follows the description in ‘Running out of Cluster’ , the second as described under ‘Using Helm’.
Unfortunately, both approaches result in the same error at an early stage.
Directly after systemctl enable --now icinga-kubernetes syslog shows:
2025-03-19T14:16:28.792875+00:00 icinga-srv-1 icinga-kubernetes[27891]: I0319 14:16:28.792607 27891 main.go:69] Starting Icinga for Kubernetes (v0.2.0)
2025-03-19T14:16:28.800794+00:00 icinga-srv-1 icinga-kubernetes[27891]: I0319 14:16:28.800739 27891 database.go:286] "Connecting to database" logger="database"
2025-03-19T14:16:28.802562+00:00 icinga-srv-1 icinga-kubernetes[27891]: I0319 14:16:28.802534 27891 main.go:178] "Importing schema" logger="database"
2025-03-19T14:16:29.382076+00:00 icinga-srv-1 icingadb[1066]: runtime-updates: Upserted 2 ServiceState items
2025-03-19T14:16:30.503633+00:00 icinga-srv-1 icinga-kubernetes[27891]: F0319 14:16:30.503253 27891 main.go:385] can't retry: can't perform "INSERT INTO `annotation` (`value`, `uuid`, `name`) VALUES (:value, :uuid, :name) ON DUPLICATE KEY UPDATE `value` = VALUES(`value`), `uuid` = VALUES(`uuid`), `name` = VALUES(`name`)": Error 1406 (22001): Data too long for column 'name' at row 26
2025-03-19T14:16:30.506539+00:00 icinga-srv-1 mariadbd[971]: 2025-03-19 14:16:30 2931 [Warning] Aborted connection 2931 to db: 'kubernetes' user: 'kubernetes' host: 'localhost' (Got an error reading communication packets)
Installing the Helm Charts works without any problems.
But after a few seconds the corresponding pod runs into an error and ends in CrashLoopBackOff.
I0319 14:13:15.765466 1 main.go:69] Starting Icinga for Kubernetes (0.2.0)
I0319 14:13:15.765883 1 database.go:286] "Connecting to database" logger="database"
F0319 14:13:16.160949 1 main.go:385] can't retry: can't perform "INSERT INTO `annotation` (`value`, `uuid`, `name`) VALUES (:value, :uuid, :name) ON DUPLICATE KEY UPDATE `value` = VALUES(`value`), `uuid` = VALUES(`uuid`), `name` = VALUES(`name`)": Error 1406 (22001): Data too long for column 'name' at row 52
Does anyone have any idea what is causing this problem?
Some information about the test environment…
It is distributed monitoring with two Master but with local databases.
Both Master running the same version.
root@icinga-srv-1:~# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.5-1)
System information:
Platform: Ubuntu
Platform version: 24.04.2 LTS (Noble Numbat)
Kernel: Linux
Kernel version: 6.8.0-55-generic
Architecture: x86_64
Build information:
Compiler: GNU 13.3.0
OpenSSL version: OpenSSL 3.0.13 30 Jan 2024
The Kubernetes cluster runs version 1.24.17, all nodes run on Ubuntu 20.04.6 or 24.04.2.
Any help would be great.
best regards,
Dietmar
