Icinga does not supply the parameter to the script
Hello everybody,
I have a problem with my custom powershell script. The powershell framework 1.4.1 is installed on the server. The script expect the name of a config-file in the same directory. Locally it works but if I embedd the script with the director, icinga does not supply the parameter.
Thats the configuration of the command:
And the service:
If you need more information, let me know.
Thank you :slight_smile:
  • Icinga 2 version used: r2.12.3-1
  • Icinga Web 2 version: 2.8.0-rc1
  • director version: master
  • Web browser used: Opera
  • Server operating system: Windows Server 2012 R2
Hi @M.Lake
I’m not sure, but are the custom vars case senstive? The argument shows
GetVolumeInfos_Configfile
but the service shows
GetVolumeInfos_configfile
Kind regards
