Hi there!
I am facing an issue that I have new hosts / services in status pending
log on satelite says:
critical/ApiListener: Config validation failed for staged cluster config sync in ‘/var/lib/icinga2/api/zones-stage/’. Aborting. Logs: ‘/var/lib/icinga2/api/zones-stage//startup.log’
startuplog od satelite says:
critical/config: Error: Validation failed for object ‘__blabla__Telegram-Service-Notification’ of type ‘Notification’; Attribute ‘users’: Object ‘test’ of type ‘User’ does not exist.
As this object user ‘test’ is defined in director
When I disable notifications it works fine with no problem and changes are immediatelly deployed and everything works fine, I tried to create another user and set him up in directer with same result…
