Hi Everyone,
I’m trying to use Manubulon SNMP plugins and configure them through Icinga Director.
In general, it works, but I have an issue with assigning SNMP Community variable in Service template. I’m trying to have something like this:
template Service "snmp-template" {
vars.snmp_community = ManubulonSnmpCommunity
I went to Icinga Director
→ Commands
→ External Commands
and found snmp-memory
check and I’ve added snmp_community
field from the list.
If I go to Icinga Director
→ Data Fields
I see snmp_community
field there.
In Icinga Director
→ Service Templates
I have added snmp-template
like this:
with added vars.snmp_community = ManubulonSnmpCommunity
field declared as snmp_community
in Fields
menu.
My check is still using public
community. I was trying to change this in the code and it works, but I would like to have a more clean setup.
Is this the correct way of using variables with director?
