Hello all,
I have a question about the Host Choice Templates in Icinga Director. I have a choice template stored in the Icinga Director. Unfortunately, this is not displayed to me when I want to add a new host via a host template.
Can you tell me what I need to do so that the created choice can be used when creating a host? Unfortunately I have not found anything in the documentation.
Best regards
I was able to solve the first problem. The multiple choice template now works for a host template.
My problem is currently still:
I have a master host template ,generic-host". All other host templates import this host template. I have assigned the multiple choice template to the generic-host template. Unfortunately, my choices are not displayed in the other templates, but only for the generic-host template.
Does anyone have a suggestion how I can roll out the choices for all host templates?
Many greetings
