I’m trying to import a buch of ‘Data Fields’ into director via Import Source (currently a csv from fileshipper module) and a Sync Rule (where the missing object should be).
similar post is of no use, as people endup importing icinga objects (hosts, services , … with custom vars and the like); but not Director ‘Data Fields’ nor ‘Data field categories’
Is this a missing feature? a per-design unsupported issue? or is there a proper way to import Data fields and Data categories into Director?
Desired ‘director-objects’
Allowed imports:
(Data list entry is the only one visible on the Sync rule | Create fields | object Type)
from browser dev tools, the combo list to select the object type can be extracted:
<option value="">- please choose -</option>
<option value="host">Host</option>
<option value="hostgroup">Host Group</option>
<option value="service">Service</option>
<option value="servicegroup">Service Group</option>
<option value="serviceSet">Service Set</option>
<option value="user">User</option>
<option value="usergroup">User Group</option>
<option value="datalistEntry" selected="selected">Data List Entry</option>
<option value="command">Command</option>
<option value="timePeriod">Time Period</option>
<option value="notification">Notification</option>
<option value="scheduledDowntime">Scheduled Downtime</option>
<option value="dependency">Dependency</option>
<option value="endpoint">Endpoint</option>
<option value="zone">Zone</option>
Can Data Fields and its categories be imported at all?
Is there a way to do so?
Thanks in advance,
- Director version (System - About):
Name director State enabled Version 1.10.2 Git commit 2f76c38005ea395a78cfad124e4d6cbc8aa356b4
- Icinga Web 2 version and modules (System - About):
|Icinga Web 2 Version|2.11.4|
|Git commit|11453bfa92a70a44efbf7f966f5e7f27e9300a28|
|PHP Version|7.3.29|
## Loaded Libraries
|icinga/icinga-php-thirdparty|0.11.0|
|icinga/icinga-php-library|0.10.1|
## Loaded Modules
|cube||1.2.1|
|director||1.10.2|
|doc||2.11.4|
|icingaweb2-theme-company||1.0.0|
|incubator||0.20.0
|monitoring||2.11.4|
|reactbundle||0.9.0|
|fileshipper|1.2.0|
- Icinga 2 version (
icinga2 --version):
icinga2 - The Icinga 2 network monitoring daemon (version: 2.13.2-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-1160.80.1.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.5
Build host: runner-hh8q3bz2-project-322-concurrent-0
OpenSSL version: OpenSSL 1.0.2k-fips 26 Jan 2017
- Operating System and version:
- Webserver, PHP versions
