ricardos
(Ricardo Santos)
1
I’am seeing this problem in the icingaweb2 board after Director installation.
I followed this installation documentation:
https://icinga.com/docs/icinga-director/latest/doc/75-Background-Daemon/
This is exception using icingacli:
DB configuration is not valid
This is my Director database settings:
How to fix this problem?
- Director version (System - About): 1.10.2
- Icinga Web 2 version and modules (System - About): 2.11.2
- Icinga 2 version (
icinga2 --version
): r2.13.6-1
- Operating System and version: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
- Webserver, PHP versions: Apache/2.4.52 (Ubuntu) / PHP 8.1.2
Good day,
have you imported the mysql schema?
If you add the director resource and then test the connection through the Icingaweb.
Do you get back there as feedback that the connection was successful?
Does the command systemctl status icinga-director.service
give any more hints?
ricardos
(Ricardo Santos)
3
Yes, I’m used the migrate command
icingacli director migration run
The following command tells me everything is ok
icingacli director migration pending
output: There are no pending migrations
Yes, I did, it’s in the print of the topic body
output:
● icinga-director.service - Icinga Director - Monitoring Configuration
Loaded: loaded (/etc/systemd/system/icinga-director.service; enabled; vendor preset: enab>
Active: active (running) since Tue 2022-12-20 17:12:26 UTC; 1 day 22h ago
Docs: https://icinga.com/docs/director/latest/
Main PID: 301908 (icingacli)
Status: "running, db: no configuration"
Tasks: 1 (limit: 2258)
Memory: 9.8M
CPU: 14.667s
CGroup: /system.slice/icinga-director.service
└─301908 "icinga::director: running, db: no configuration" "" "" "" ""
Dec 20 17:12:26 icinga.xxxx.com systemd[1]: Starting Icinga Director - Monitoring Config>
Dec 20 17:12:26 icinga.xxxx.com systemd[1]: Started Icinga Director - Monitoring Configu>
Dec 20 17:12:26 icinga.xxxx.com icingadirector[301908]: DB configuration is not valid
you probably can’t do the kickstart in the director either, can you?
I found another older problem in the forum. Maybe this will help you too. Unfortunately, I have no other ideas at the moment
ricardos
(Ricardo Santos)
5
kickstart in the director is set
