Icinga Director - commands - fields mixing up names
I’m using icingaweb2-module-director 1.11.4-1 on Debian Trixie. In Director I created a command check_network with arguments -c, (value: $network_critical$), -w (value: $network_warning$) and (no_key) (value: $network_delay$).
Then I go to tab Fields, and I want to add these arguments there. In the dropdown list Fields I have these under Suggested fields:
network_critical (network_critical)
network_delay (network_delay)
network_delay (network_warning)
Notice that I have two times network_delay, but one of them appears to be network_warning instead. How can I fix this? I tried deleting the command completely and recreating it, but that does not help.
go to /icingaweb2/director/data/fields
and search for your field. It looks like you mixed up Field name and caption in one field
