So, if i create new own Command (the name is https), then the new command not included arguments. It is possible import the arguments to this new command ?
Yes, that is a bit confusing, that the arguments are not shown when a command is imported.
I stumbled upon this some time back and created a request on github for this:
But if you import the http command into your own https you can use those args.
I would suggest you add the variable fields (via the fields tab) to the http command. After this you will see those fields in you https command and can use/fill them
