I assume that my config would prevent notifications on “Brother MFC-L2710DN” if the dependency group TEST (dummy1, dummy2 both critical) is no longer satisfied but notifications are still sent out.
so here are my questions:
Does redundancy_group work on applyrules?
Is there something wrong in my logic?
I use applyrules because I’m trying to get it to work with director and this are the actuall rendered and validated config files, after patching the director
Sorry. My mistake. At least one parent OK means the dependency is fulfilled and does NOT prevent notifications. But if both are critical, you should NOT get notifications (at the first sight).
Well, you can’t Monitoring Basics - Icinga 2. It’s mandatory for host dependencies. If you omit it here, the apply rule will determine the parent host dynamically.
