Hello dear folks,
I think I’ve stumbled across a problem that many of you have encountered, but not in this way.
After installing icinga2 and icingaweb2, the health monitor detected that my database is either not running or the icingadb feature is not active.
I already restarted the whole system and all services.
As you can see in the screenshots below, my database is running and the feature is enabled. The validation of the configurations on the web interface is also working.
Thanks for your support ![]()
Running Features:
Running DB:
- Icinga Web 2 version: 2.12.1
- Used modules and their versions (System - About)
- Web browser used: Safari - Version 17.4.1 (19618.1.15.11.14)
- Icinga 2 version used: Version: r2.14.2-1
- PHP version used: v8.2.18
- OS: Debian 12
