I know this is an odd one.
I am using Icinga 2 on some of my macOS computers in the role of Icinga client.
Icinga 2 is built from source with dependencies provided by MacPorts.
So far I was able to make it work. I have it running on macOS 10.15.7 Catalina.
Today I compiled Icinga 2 on macOS 11.1 Big Sur. Compilation went fine.
I am able to run the binary:
/opt/local/sbin/icinga2 --version 17:08:31
icinga2 - The Icinga 2 network monitoring daemon (version: r2.12.3-1)
Copyright (c) 2012-2020 Icinga GmbH (https://icinga.com/)
System information:
Platform: macOS
Platform version: 11.1
Kernel: Darwin
Kernel version: 20.2.0
Architecture: x86_64
Build information:
Compiler: Clang 11.0.3.11030032
Build host: our.company.server
OpenSSL version: OpenSSL 1.1.1i 8 Dec 2020
Application information:
General paths:
Config directory: /opt/local/etc/icinga2
Data directory: /opt/local/var/lib/icinga2
Log directory: /opt/local/var/log/icinga2
Cache directory: /opt/local/var/cache/icinga2
Spool directory: /opt/local/var/spool/icinga2
Run directory: /opt/local/var/run/icinga2
Old paths (deprecated):
Installation root: /opt/local
Sysconf directory: /opt/local/etc
Run directory (base): /opt/local/var/run
Local state directory: /opt/local/var
Internal paths:
Package data directory: /opt/local/share/icinga2
State path: /opt/local/var/lib/icinga2/icinga2.state
Modified attributes path: /opt/local/var/lib/icinga2/modified-attributes.conf
Objects path: /opt/local/var/cache/icinga2/icinga2.debug
Vars path: /opt/local/var/cache/icinga2/icinga2.vars
PID path: /opt/local/var/run/icinga2/icinga2.pid
However when I try to run it as daemon it exits with code 1.
/opt/local/sbin/icinga2 daemon --log-level debug
[2020-12-18 17:08:13 +0100] information/cli: Icinga application loader (version: r2.12.3-1)
[2020-12-18 17:08:13 +0100] notice/cli: Spawning seemless worker process doing the actual work
[2020-12-18 17:08:13 +0100] notice/cli: Spawned worker process (PID 784), waiting for it to load its config
[2020-12-18 17:08:13 +0100] information/cli: Loading configuration file(s).
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/etc/icinga2/icinga2.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/etc/icinga2/constants.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/etc/icinga2/zones.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/itl
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/command-icinga.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/command-plugins.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/big-data.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/databases.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/hardware.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/icingacli.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/ipmi.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/logmanagement.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/metrics.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/network-components.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/network-services.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/operating-system.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/raid-controller.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/smart-attributes.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/storage.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/virtualization.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/vmware.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/plugins-contrib.d/web.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/manubulon
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/command-plugins-manubulon.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/windows-plugins
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/command-plugins-windows.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/nscp
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/share/icinga2/include/command-nscp-local.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/etc/icinga2/features-enabled/api.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/etc/icinga2/features-enabled/mainlog.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/var/lib/icinga2/api/packages/_api/include.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/var/lib/icinga2/api/packages/_api/ef750578-3108-4107-8a5f-80bc6ec20779/include.conf
[2020-12-18 17:08:13 +0100] notice/ConfigCompiler: Compiling config file: /opt/local/var/lib/icinga2/api/packages/_api/ef750578-3108-4107-8a5f-80bc6ec20779/../active.conf
[2020-12-18 17:08:13 +0100] information/ConfigItem: Committing config item(s).
[2020-12-18 17:08:13 +0100] debug/Timer: TimerThreadProc started.
[2020-12-18 17:08:13 +0100] notice/WorkQueue: Spawning WorkQueue threads for 'DaemonUtility::LoadConfigFiles'
[2020-12-18 17:08:13 +0100] notice/ApiListener: Updating cache: Config package '_api' has active stage 'ef750578-3108-4107-8a5f-80bc6ec20779'.
[2020-12-18 17:08:13 +0100] information/ApiListener: My API identity: our.company.server
[2020-12-18 17:08:13 +0100] notice/TlsUtility: Available TLS cipher list: TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-ECDSA-AES256-GCM-SHA384 ECDHE-RSA-AES256-GCM-SHA384 ECDHE-ECDSA-CHACHA20-POLY1305 ECDHE-RSA-CHACHA20-POLY1305 ECDHE-ECDSA-AES128-GCM-SHA256 ECDHE-RSA-AES128-GCM-SHA256 ECDHE-ECDSA-AES256-SHA384 ECDHE-RSA-AES256-SHA384 ECDHE-ECDSA-AES128-SHA256 ECDHE-RSA-AES128-SHA256 DHE-RSA-AES128-GCM-SHA256 DHE-RSA-AES256-GCM-SHA384 AES256-GCM-SHA384 AES128-GCM-SHA256
[2020-12-18 17:08:13 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2020-12-18 17:08:13 +0100] information/ConfigItem: Instantiated 235 CheckCommands.
[2020-12-18 17:08:13 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2020-12-18 17:08:13 +0100] information/ConfigItem: Instantiated 2 Endpoints.
[2020-12-18 17:08:13 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2020-12-18 17:08:13 +0100] information/ConfigItem: Instantiated 6 Zones.
[2020-12-18 17:08:13 +0100] information/ScriptGlobal: Dumping variables to file '/opt/local/var/cache/icinga2/icinga2.vars'
[2020-12-18 17:08:13 +0100] notice/WorkQueue: Stopped WorkQueue threads for 'DaemonUtility::LoadConfigFiles'
[2020-12-18 17:08:13 +0100] notice/cli: Notifying umbrella process (PID 771) about the config loading success
[2020-12-18 17:08:13 +0100] notice/cli: Worker process successfully loaded its config
[2020-12-18 17:08:13 +0100] notice/cli: Waiting for the umbrella process to let us doing the actual work
[2020-12-18 17:08:13 +0100] notice/cli: The umbrella process let us continuing
[2020-12-18 17:08:13 +0100] information/ConfigItem: Triggering Start signal for config items
[2020-12-18 17:08:13 +0100] notice/WorkQueue: Stopped WorkQueue threads for 'DaemonCommand::Run'
[2020-12-18 17:08:13 +0100] notice/cli: Seemless worker (PID 784) stopped, stopping as well
I don’t see anything related to exiting suddenly in the debug output. What could I do to troubleshoot more and find out why is icinga2 daemon
exiting with code 1?
