Hello Icinga Community,
I am experiencing Icinga crashes on my HA system. I have two master nodes checking 2625 host and 16517 services. All was working great without any problems, than all the sudden the application crashed. The icinga2.log files do not have any error message showing. The only thing I notice in the logs is a lot of ‘PID xxxxx was terminated by signal 9’ error messages. Soon after this message, I see a lot of ‘client disconnect’ messages. What could be causing my system to crash? I have not made any major changes. I have only added more host and services to check.
Has anyone experienced this problem? Thanks in advance for your help.
Alex
icinga2 -V
[2021-12-13 13:57:12 -0500] warning/Application: Failed to adjust resource limit for open file handles (RLIMIT_NOFILE) with error "Operation not permitted"
[2021-12-13 13:57:13 -0500] warning/Application: Failed to adjust resource limit for open file handles (RLIMIT_NOFILE) with error "Operation not permitted"
icinga2 - The Icinga 2 network monitoring daemon (version: 2.11.11-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
System information:
Platform: Red Hat Enterprise Linux Server
Platform version: 7.7 (Maipo)
Kernel: Linux
Kernel version: 3.10.0-1160.49.1.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.5
Build host: runner-hh8q3bz2-project-507-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
icinga2 daemon -C
[2021-12-13 13:59:02 -0500] warning/Application: Failed to adjust resource limit for open file handles (RLIMIT_NOFILE) with error "Operation not permitted"
[2021-12-13 13:59:02 -0500] information/cli: Icinga application loader (version: 2.11.11-1)
[2021-12-13 13:59:02 -0500] information/cli: Loading configuration file(s).
[2021-12-13 13:59:35 -0500] information/ConfigItem: Committing config item(s).
[2021-12-13 13:59:36 -0500] information/ApiListener: My API identity: USDCPVDAS120.prod.sunchemical.com
[2021-12-13 13:59:37 -0500] warning/globals.getHostGeoLocation: Cannot find 'USBC' in GeoLocationShort
[2021-12-13 13:59:37 -0500] warning/globals.getHostGeoLocation: Cannot find 'USEP' in GeoLocationShort
[2021-12-13 13:59:38 -0500] warning/globals.getHostGeoLocation: Cannot find 'USEP' in GeoLocationShort
[2021-12-13 13:59:45 -0500] information/WorkQueue: #4 (DaemonUtility::LoadConfigFiles) items: 0, rate: 4.4/s (264/min 264/5min 264/15min);
[2021-12-13 13:59:45 -0500] information/WorkQueue: #5 (GraphiteWriter, graphite) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-12-13 13:59:46 -0500] information/WorkQueue: #7 (ApiListener, RelayQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-12-13 13:59:46 -0500] information/WorkQueue: #8 (ApiListener, SyncQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-12-13 14:01:45 -0500] warning/ApplyRule: Apply rule 'scheduled_task_last_ran_month' (in /etc/icinga2/zones.d/global-templates/services-windows-others.conf: 35:1-35:124) for type 'Service' does not match anywhere!
[2021-12-13 14:01:45 -0500] warning/ApplyRule: Apply rule 'AD_User_Eventlog_Check_2019' (in /etc/icinga2/zones.d/global-templates/Application_Groups/ADDC/services.conf: 35:1-35:43) for type 'Service' does not match anywhere!
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 GraphiteWriter.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 NotificationComponent.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 LivestatusListener.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 CheckerComponent.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 208 Users.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 13 ServiceGroups.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 4 TimePeriods.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 783 Zones.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 16484 Services.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 14756 ScheduledDowntimes.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 28619 Notifications.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 50393 Dependencies.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 2 NotificationCommands.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 17 Comments.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 IcingaApplication.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 782 Endpoints.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 241 HostGroups.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 2609 Hosts.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 EventCommand.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 7533 Downtimes.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 247 CheckCommands.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 FileLogger.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 5 ApiUsers.
[2021-12-13 14:01:45 -0500] information/ConfigItem: Instantiated 1 ApiListener.
[2021-12-13 14:01:45 -0500] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2021-12-13 14:01:45 -0500] information/cli: Finished validating the configuration file(s).
