For now i just have one client and one master on linux/debian 9 machines. I am trying to add the client to infrastructure . When i go to view my hosts on the icinga web it shows my client is “PENDING” under Service Problems. If i go to Host Problems tab it says my client is down ( it is not). My client has the correct trustedcert and it has a valid client cert and I have confirmed that it is not ‘self-signed’ using the openssl command.
Icinga2 feature list (master) – Enabled Features: api checker ido-mysql mainlog
Icigna2 feature list (client) – api checker mainlog notification
icinga2 daemon -C on both machines does not show any errors and on my master its shows that I have two ‘Hosts’ , ‘Zones’ and ‘Endpoints’.
In /var/log/icinga2/icinga2.log i see some messages that i believe may be helpful . They are : "Check command for object ‘icingaClientHostname’ (PID 32423, arguments: ‘/usr/lib/nagios/plugins/check_ping’ ‘-H’ ‘127.0.0.1’ ‘-c’ ‘5000,100%’ ‘-w’ ‘3000,80%’) terminated with code 128, output: <Terminated by signal 9 (Killed). >’
Any help would be appreciated and I can provide more details if needed .
ok, whats the content of /etc/icinga2/zones.conf on the client and how is the Endpoint object on the master configured (again /etc/icinga2/zones.conf)?
The way I am configuring my setup I have the zones, hosts and endpoint configurations specified on the master machine for each client under the repository.d directory. So under /etc/icinga2/repository.d/“clienthostname”.conf i have defined the host as such:
object Zone “clienthostname” {
endpoints = [ “clienthostname” ]
parent = “master”
I have also confirmed that the client certs have the correct names/spellings
The thing is, the “infrastructure layer” has to be configured on the machines before you can use them together.
You can NOT define zones and endpoints on the master and deploy them to the clients.
I will try your suggestion later today. So once I define the zones how you mentioned on the client and master will I be able to go back to the way I am currently set up? Meaning the hosts/zone/endpoint definitions on my master.
