Hello everybody,
I need to install Auditbeat (ELK stack: Auditbeat: Lightweight Shipper for Audit Data | Elastic) on hosts where Icinga system is also installed.
I would like to know, if Icinga makes use of the Auditd service, and if it can be disabled without compromising the correct functioning of Icinga, since the Auditd and Auditbeat service conflict and therefore cannot work together.
Thank you
