Icinga API
Hi
I’m trying to use icinga API to add some host with python script.
If I try to do it manually no problem, but with some script it doesn’t work…
My part of script with problem:
request_url = “https://localhost:5665/v1/objects/hosts/hostname
headers = {
‘Accept’: ‘application/json’,
‘X-HTTP-Method-Override’: ‘PUT’
data = {
“templates”: [“generic-host”],
“attrs”: {
“address”:ip,
“vars”: {
“zone”:“zone1”,
r = requests.post(request_url, …
My result return is:
Result: {“results”: [{“code”: 500.0, “errors”: ["Error: Validation failed for object ‘hostname’ of type ‘Host’; Attribute ‘check_command’: Attribute must not be empty.
I tried to add a command_check but it doesnt work anymore. (same error)
“check_command”: “hostalive”,
And if I try to curl command directly on my master.icinga it works…
I’m looking on API doc but for the moment no idea…
If someone has, it should be great.
Alex
How and where in your request?
Example here:
                    data = {
                        "templates": ["generic-host"],
                        "attrs": {
                                 "address":ip,
                                 "check_command": "hostalive",
                                 "vars": {
                                         "zone":"zone1",
And result:
And you’re really using hostalive which exists at /v1/objects/checkcommands/hostalive? Please also share the output of icinga2 --version on that host.
curl -k -s -u XXX:XXX -H ‘Accept: application/json’ -H ‘X-HTTP-Method-Override: GET’ ‘https://localhost:5665/v1/objects/checkcommands’ | json_pp | grep hostalive
“name” : “hostalive”
so seems yes.
To me more precise:
GET https://localhost:5665/v1/objects/checkcommands/hostalive
returns me all information about hostalive checkcommand
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.2-1)
System information:
Platform: Debian GNU/Linux
Platform version: 10 (buster)
General paths:
Run directory: /run/icinga2
Thanks for help
And what is really strange for me is that if I curl directly a cul command it works fine (without to precise a checkcommand)
Example:
curl -vv -k -X PUT -u “admin:${XXXXXXX}” -H ‘Accept: application/json’ -H ‘Content-Type: application/json’ -L “https://localhost:5665/v1/objects/hosts/myhostnameToAdd” -d “{“templates”:
[“generic-host”],
“attrs”: {
“address”: “IPToAdd”, “zone”: “zonre1”
  • Connection #0 to host localhost left intact
    {“results”:[{“code”:200.0,“status”:“Object was created”}]}
Sorry I’m dumb… I forget to pass data=json.dumps(data)) on my request.post script …
Now it works!
Thanks for help!
