Icinga API Documentation Error
I am not sure where to report this but I found an error in the Icinga API docs, https://icinga.com/docs/icinga2/latest/doc/12-icinga2-api/#event-stream-response the code in the curl example contains an error.
Your example:
$ curl -k -s -u root:icinga -H 'Accept: application/json' \
-X POST 'https://localhost:5665/v1/events' \
-d '{ "queue": "myqueue", "types": "CheckResult", "filter": "event.check_result.exit_status==2" }'
Results in a server 500 error
“types” according to the API documentation is an array (https://icinga.com/docs/icinga2/latest/doc/12-icinga2-api/#icinga2-api-event-streams)
So… the correct call is: -
-d '{ "queue": "myqueue", "types": ["CheckResult"], "filter": "event.check_result.exit_status==2" }'
Cheers!
Ein hefferweitzen für mich denk ich :wink:
you could create a pull request to apply those changes :slight_smile:
https://github.com/Icinga/icinga2
Greetz
Heyhey!
As Alex said, a PR on Github would be the way to go :slight_smile:
I’ll just point you to the file while we’re at it to get started :slight_smile:
Have a nice day!
Feu
Hi Feu,
I have checked out the code, created a branch and carried out the changes. As I do not have write permissions to the repository I am unable to create a pull requests.
What is your process.
Kind regards
Peter
Hey!
The workflow on GitHub is, that you make a “fork” (that’s like a clone of the repository on your account) and then you can create the pull request from there.
When you look at a project, you can usually just select a file and use the web editor to make changes, which automatically generates you a fork, if you don’t have write access. And from there you can also submit the pull request.
If you already made changes to your local clone of the project, I think it would be easiest if you just copy-paste them over into the editor in the web :slight_smile:
You can also have a look at GitHubs forking workflow guide.
When you got the process down, you’ve got your first steps done to contributing more to open source projects! :slight_smile:
Thank you!
Feu
Hello Feu,
forking done :wink: (English humour) LOL
pull request executed.
Peter
Thank you so much!
Onto a bright forking future in the open source community! :grin::+1:
