Hi
on your “bookmarks”, “experience”, do you have any API command line to count quickly how many hosts you have?
Or services?
In fact I want to make a script to list and monitore how many hosts, services i manage.
Tanks.
Alex
Hi
Or services?
Tanks.
Alex
Hi.
icinga2 object list --type Host
icinga2 object list --type Service
# A (quite poor) example:
icinga2 object list --type Host | grep -c "of type 'Host'"
Or analogue:
curl -k -s -u api_user:api_pass 'https://your.server:5665/v1/objects/hosts'
# or to count (another poor example)
curl -k -s -u api_user:api_pass 'https://your.server:5665/v1/objects/hosts' | jq '.' | grep -c '__name'
curl -k -s -u api_user:api_pass 'https://your.server:5665/v1/objects/services'
If you dont need a filter for hosts and services you can use the icinga command from ITL to create a service that will deliver all data and write it to your perfdata write of your choice.
Else i would use the icinga console to get the needed counts as a number, there you can filter also. a simple example:
[root@koelin01 ~]# ICINGA2_API_USERNAME=root ICINGA2_API_PASSWORD=heinbloed icinga2 console --connect 'https://localhost:5665/' --eval 'get_objects(Host).len()'
23.0
Thanks for your answers that’s great.
All is ok for me
Have a good day
Alex
Keep in mind that the debug console also means operating on an open heart, so use that with care. For production use cases, I’d recommend to use the /v1/objects/<type> URL endpoints and count the received results.
