after we migrated one of the Icinga Master server to another site, all Linux Agents were reloading the configuration in a loop.
[2020-08-19 09:21:21 +0700] information/ApiListener: Restarting after configuration change.
[2020-08-19 09:21:22 +0700] information/WorkQueue: #6 (ApiListener, SyncQueue) items: 0, rate: 0.0166667/s (1/min 1/5min 1/15min);
[2020-08-19 09:21:22 +0700] information/WorkQueue: #5 (ApiListener, RelayQueue) items: 0, rate: 0.0166667/s (1/min 1/5min 1/15min);
[2020-08-19 09:21:23 +0700] information/Application: Got reload command: Starting new instance.
[2020-08-19 09:21:23 +0700] information/Application: Reload requested, letting new process take over.
[2020-08-19 09:21:23 +0700] information/ApiListener: 'api' stopped.
[2020-08-19 09:21:23 +0700] information/CheckerComponent: 'checker' stopped.
[2020-08-19 09:21:23 +0700] information/FileLogger: 'main-log' started.
[2020-08-19 09:21:23 +0700] information/ApiListener: 'api' started.
[2020-08-19 09:21:23 +0700] information/ApiListener: Started new listener on '[0.0.0.0]:5665'
[2020-08-19 09:21:23 +0700] information/CheckerComponent: 'checker' started.
[2020-08-19 09:21:23 +0700] information/ConfigItem: Activated all objects.
[2020-08-19 09:21:30 +0700] information/ApiListener: New client connection for identity 'master.domain.tld' from [10.2.1.161]:42928
[2020-08-19 09:21:30 +0700] information/ApiListener: Requesting new certificate for this Icinga instance from endpoint 'master.domain.tld'.
[2020-08-19 09:21:30 +0700] information/ApiListener: Sending config updates for endpoint 'master.domain.tld' in zone 'master'.
[2020-08-19 09:21:30 +0700] information/ApiListener: Finished sending config file updates for endpoint 'master.domain.tld' in zone 'master'.
[2020-08-19 09:21:30 +0700] information/ApiListener: Syncing runtime objects to endpoint 'master.domain.tld'.
[2020-08-19 09:21:30 +0700] information/ApiListener: Finished syncing runtime objects to endpoint 'master.domain.tld'.
[2020-08-19 09:21:30 +0700] information/ApiListener: Finished sending runtime config updates for endpoint 'master.domain.tld' in zone 'master'.
[2020-08-19 09:21:30 +0700] information/ApiListener: Sending replay log for endpoint 'master.domain.tld' in zone 'master'.
[2020-08-19 09:21:31 +0700] information/ApiListener: Finished sending replay log for endpoint 'master.domain.tld' in zone 'master'.
[2020-08-19 09:21:31 +0700] information/ApiListener: Finished syncing endpoint 'master.domain.tld' in zone 'master'.
[2020-08-19 09:21:31 +0700] information/ApiListener: Applying config update from endpoint 'master.domain.tld' of zone 'master'.
[2020-08-19 09:21:31 +0700] information/ApiListener: Applying configuration file update for path '/var/lib/icinga2/api/zones/director-global' (0 Bytes). Received timestamp '2020-08-19 09:21:31 +0700' (1597803691.941806), Current timestamp '2020-08-19 09:21:21 +0700' (1597803681.928448).
[2020-08-19 09:21:31 +0700] information/ApiListener: Restarting after configuration change.
To my understanding it tries to reload the director-global zone, which isn’t used and also has 0 Byte. For now I have removed the director-global zone from the zones file so the Agent don’t reload every 10s, but I want to understand why this happened.
