I use servername.conf (for hosts), and services.conf for all servcies. But now, I want check only services in ipfire server, but I dont want check/ping gateway server/ host connectivity from master node because ipfire server rejected connectivity. So I use this code:
apply Service "pakfire" {
import "1day-service"
check_command = "pakfire_status"
assign where ???
But what code used to the assign where command? Because I dont want to connect host, so not good match “something”, host.display_name.
The pakfire_status contains all important data for connect server, and running command.
