Icinga 2 service not restarting
in these days I had a problem with icinga and the notifications, so I tried to restart the service (it was active) with systemctl restart icinga2.service he didn’t restarted and now is unavailable.
After, I noticed that a process (syslog-ng) was using the CPU at 160% so I changed a conf file and restarted the service…now it uses 32% of CPU and all is apparenlty fair.
So I thinked: “now Icinga2 don’t have any problem for restarting, let’s try to make it run”
I used systemctl restart icinga2.service but Icinga don’t want to come up!
systemctl status icinga2.service says that:
icinga2.service: Main process exited, code=killled, status=6/ABRT
Failed to start Icinga /host7service/network monitoring system.
icinga2.service: Unit entered failed state.
icinga2.service: Failed with result ‘signal’.
It also says that I can find more infos under /var/log/icinga2/crash but all the files are empty!
What can I do?
All the other service s are running…Docker, Apache2, mysql…
What can I do?
The docker containers are running…
Giulia :kiss:
What was the problem?
is unavailable.
Anything useful in /var/log/icinga2/icinga2.log or
/var/log/icinga2/startup.log ?
changed a conf file
Which one?
What did you change?
fair.
So, to be clear, syslog-ng is using 32% of your CPU?
That seems like a great deal to me.
to make it run”
What can I do?
Troubleshooting - Icinga 2 may help.
Antony.
You might have an error in your conf files. For checking you need to run
icinga2 daemon -C
The problem was that the notifications randomly stopped to be sent to my e-mail…
in /var/log icinga2.log doesn’t exist…same for startup.log
in /var/log/icinga2 directory i found only old logs and the “crash” directory have empty files inside.
I found these files:
in /var/log/error there is:
icingasrv systemd[1]: failed to start Icinga host/service/network monitoring service
icingasrv syslog-ng[16589]: I/O error occoured while writing; fd=‘56’, error=‘Broken pipe (32)’
sorry if I don’t report all the things but I’m in a sort of matrioska of RDP’s, VmWare ecc ecc ecc so I’m writing logs by hand
in /var/log/syslog there is:
icingasrv systemd[1]: icinga2.service: Failed with result ‘signal’.
And there is also an error that sounds like:
icingasrv icinga2[5616]: error: Function call ‘std::ifstream::open’ for file /NOW/IT/REFERS/TO/A/LONG/PATH failed with error code 2, ‘No such file or directory’
(0) Compiling configuration file /NOW/IT/REFERS/TO/A/LONG/PATH
For syslog-ng, i changed the line with #ForwardToSyslog=yes in ForwardToSyslog=no in /etc/systemd/journald.conf…
Now it uses 32% of CPU but is better than 160%…
I already readed https://icinga.com/docs/icinga2/latest/doc/15-troubleshooting/
The output don’t seems to contain errors…
sounds odd with the syslog-ng failing so hard on the file descriptor level. Can you add some more specs of your system, like the output of
  • icinga2 --version
  • icinga2 daemon -C
  • How many CPU, RAM, etc. is available, e.g. htop
icinga2 --version
System information:
Platform: Debian GNU/Linux
Platform version: 9 (stretch)
Kernel: Linux
Kernel version: 4.9.0-6-amd64
Architecture: x86_64
Build information:
Compiler: GNU 6.3.0
Build host: 486e413fb159
Application information:
general paths:
data directory: /var/lib/icinga2
Spool diectory: /var/spool/icinga2
Run directory: 7run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Sate path: /var/lib/icinga2/icinga2.state
icinga2 daemon -C
information/cli: Icinga application loader 8version: r2.10.2-1)
information/cli: Loading configuration file(s).
information/ConfigItem: Commiting config item(s).
information/ApiListener: My API identity: icingasrv.local
information/ConfigItem: Instantiated 1 ScheduledDowntime.
information/ConfigItem: Instantiated 497 Services.
information/ConfigItem: Instantiated 1 icingaApplication.
information/ConfigItem: Instantiated 486 Hosts.
information/ConfigItem: Instantiated 1 fileLogger.
information/ConfigItem: Instantiated 2 NotificationCommands.
information/ConfigItem: Instantiated 13 Notifications.
information/ConfigItem: Instantiated 1 NotificationComponent.
information/ConfigItem: Instantiated 2 HostGroups.
information/ConfigItem: Instantiated 1 ApiListener.
information/ConfigItem: Instantiated 1 GraphiteWriter.
information/ConfigItem: Instantiated 1 PerfdataWriter.
information/ConfigItem: Instantiated 1 CheckerComponent.
information/ConfigItem: Instantiated 3 Zones.
information/ConfigItem: Instantiated 1 Endpoint.
information/ConfigItem: Instantiated 1 ApiUser.
information/ConfigItem: Instantiated 1 User.
information/ConfigItem: Instantiated 1 IdoMysqlConnection.
information/ConfigItem: Instantiated 215 CheckCommands.
information/ConfigItem: Instantiated 1 usergroup.
information/ConfigItem: Instantiated 3 ServiceGroups.
information/ConfigItem: Instantiated 3 Timeperiods.
information/ScriptGlobal: Dumping variabiles to file ‘/var/cache/icinga2/icinga2.vars’
information/cli: Finished validating the configuration file(s).
I cannot install htop because I don’t have free space in /var/cache/apt/archives…
The CPU processes that use more CPU are:
syslog-ng 26,3%
top 10,5%
jbd2/dm-0-8 5,3%
mysqld 5,3%
Tthe others are at 0%
The host is a VmWare virtual machine witch:
Consumed host CPU: 1,6 GHz
Consumed host memory: 3,94 GB
Active guest memory: 491 MB
Storage provisioned: 120 GB
Storage uncommited: 1,03 KB
Storage not-shared: 64,11 GB
Storage used: 64,11 GB
In the graph of VmWare the consumed host memory seems to be near the 100%
with the free -m command:
mem total: 3955
mem used: 2093
mem free: 327
mem shared: 70
mem buff/cache: 1535
mem available: 1527
swap total: 2047
swap used: 157
swap free: 1890
Your issues seem to be I/O related. You could try and run sar -b and see if the numbers are too big.
Also worth checking VMware logs for issues as it could be affected by underlying storage.
The memory situation reported by VmWare is not good…
You could try to reboot the VM but there is a good risk that it will refuse to start again.
Meaning to say, /var is full?
the output of “df -h /var” says that the dimension is 44G and the used part is 42G…available 0 and usage 100%
Holy moly, you should take immediate action here. Whenever daemons cannot write their logs to /var/log that’s really bad for their runtime, likewise /var/lib/mysql won’t be able to store things in the database.
Try
du -h --max-depth=1
to identify big directories. Highly likely logs are huge and need to be purged.
12K ./www
20G ./spool
5,2G ./log
7,5G ./lib
5,0M ./backups
4,0K ./opt
44K ./mail
4,0K ./local
1,4G ./cache
508K ./tmp
34G .
This can be the issue related to ther icinga2 service?
Dive deeper into the directories and figure out why log for instance is 5.2 GB in size. Try deleting non-required files and free up space. Oh, and spool has 20GB of data … did you by chance enable the perfdata feature but not use PNP for metrics?
This is related to any service on your host, all of them suffer right now and the CPU load is increasing because of that.
In terms of partitions I strongly recommend to create new ones for
  • /var/log
  • /var/lib/mysql
to separate them from normal operations.
Thank youuu now icinga2.service restarted and the e-mail restarted to be inoltrated!!!
Thank you so much!!!
