Icinga 2 communication schemas
As I have posted them before, I’ll also post them here and hope they are useful for someone when figuring out a problem or explaining how Icinga 2 communicates on the inside.
Icinga 2 + Icinga Web 2 + Icinga Director + Graphite
Icinga 2 + Icinga Web 2 + Icinga Director + PNP4Nagios
Hope both are correct. If not, please tell me and I will correct the error(s):slight_smile:
“IcingaWeb2 reads check-results for displaying” - I would replace that with “Icinga Web 2 reads config, status and historical data”.
done. :slight_smile:
thanks for the input!
I’d rather vote for “Reads config, status and historical data” and would put the arrow to the left on the monitoring module. Web 2 itself doesn’t read from the IDO.
better late, than never :smiley: Sounds reasonable, fixed it :slight_smile:
