Greetings, i’m trying to install icinga 2.14.1 package on Amazon Linux 2023. However i’m hitting dependency issue:
nothing provides libcrypto.so.10()(64bit) needed by icinga2-bin-2.14.1-1.amzn2.x86_64
nothing provides libcrypto.so.10(libcrypto.so.10)(64bit) needed by icinga2-bin-2.14.1-1.amzn2.x86_64
nothing provides libssl.so.10()(64bit) needed by icinga2-bin-2.14.1-1.amzn2.x86_64
nothing provides libssl.so.10(libssl.so.10)(64bit) needed by icinga2-bin-2.14.1-1.amzn2.x86_64
nothing provides libcrypto.so.10(OPENSSL_1.0.2)(64bit) needed by icinga2-bin-2.14.1-1.amzn2.x86_64
AL2023 uses OpenSSL 3.0.8, i don’t see a way to downgrade or install OpenSSL 1.0.x on this system.
I have tried to create symlinks to newer ssl libraries but this doesn’t help, the package installer still can’t find them. Is this dependency to older SSL version somehow hardcoded in the installation package? Is it possible to override this somehow with the actual OpenSSL version? With nagios plugins i was able to circumvent this by compiling modules manually but from what i read compiling icinga2 from source isn’t a supported installation method.
edit: additional information:
Following are dependencies of the icinga2-bin package:
Icinga provides its own boost libraries, this just strikes me if this could be a problem because i know we had issue with boost library versions already in som previous icinga2 version.
currently, we are using ICINGA2 on centos with version 2.12.2 and planning to move this to AL2023 image with same version or Fedora ICINGA 2.14.2
while I was trying to install this Centos ICINGA 2.12.2/Fedora ICINGA 2.14.2 package on AL2023 and it is failing due to OpenSSL dependency,
Fedora 2.14.2 version:
nothing provides libcrypto.so.10()(64bit) needed by icinga2-bin-2.14.2-1.el7.x86_64 from icinga
nothing provides libssl.so.10()(64bit) needed by icinga2-bin-2.14.2-1.el7.x86_64 from icinga
nothing provides libcrypto.so.10(libcrypto.so.10)(64bit) needed by icinga2-bin-2.14.2-1.el7.x86_64 from icinga
nothing provides libssl.so.10(libssl.so.10)(64bit) needed by icinga2-bin-2.14.2-1.el7.x86_64 from icinga
nothing provides libcrypto.so.10(OPENSSL_1.0.2)(64bit) needed by icinga2-bin-2.14.2-1.el7.x86_64 from icinga
nothing provides libboost_atomic.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_chrono.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_context.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_coroutine.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_date_time.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_filesystem.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_iostreams.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_program_options.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_regex.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_system.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libboost_thread.so.1.81.0()(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libc.so.6(GLIBC_2.38)(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libm.so.6(GLIBC_2.38)(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libstdc++.so.6(GLIBCXX_3.4.30)(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
nothing provides libstdc++.so.6(GLIBCXX_3.4.32)(64bit) needed by icinga2-bin-2.14.2-1.fc39.x86_64 from packages.icinga.com_fedora_39_release
CentOs 2.12.2 version:
nothing provides libcrypto.so.10()(64bit) needed by icinga2-bin-2.12.2-1.el7.icinga.x86_64 from icinga
nothing provides libssl.so.10()(64bit) needed by icinga2-bin-2.12.2-1.el7.icinga.x86_64 from icinga
nothing provides libcrypto.so.10(libcrypto.so.10)(64bit) needed by icinga2-bin-2.12.2-1.el7.icinga.x86_64 from icinga
nothing provides libssl.so.10(libssl.so.10)(64bit) needed by icinga2-bin-2.12.2-1.el7.icinga.x86_64 from icinga
nothing provides libcrypto.so.10(OPENSSL_1.0.2)(64bit) needed by icinga2-bin-2.12.2-1.el7.icinga.x86_64 from icinga
As per following link, OpenSSL required version is 1.1.1a for Fedora 29 but package is still looking OpenSSL 1.0.x on this system
