Icinga 1 URL Check SSL
Hi All
I wan’t to monitor with my old icinga1 server a weberserver with url.
So I found the check_http in the Nagios config. In the lconf editor I’ve put in the command under the command section: “check_http! -H URL -u https://WEBSERVER/URL/ -S” after saving and export the service display me CRITICAL - Socket timeout after 10 seconds.
Has anyone an idea how to check it correctly?
Thx
adminst
Icinga 1.x is out of support since 31.12.2018, LConf has been deprecated before too. I highly recommend to plan your migration to 2.x and the Director.
In terms of the error, I’d verify how check_http is defined and how arguments are accepted.
