- Version used 2.13.3-1.el7.icinga
- Red Hat 7.9
- Enabled features api checker ido-mysql mainlog
- Icinga Web 2 version and modules: currently not running
- Config validation:
[2022-06-16 10:45:31 -0400] information/cli: Icinga application loader (version: r2.13.3-1)
[2022-06-16 10:45:31 -0400] information/cli: Loading configuration file(s).
[2022-06-16 10:45:31 -0400] information/ConfigItem: Committing config item(s).
[2022-06-16 10:45:31 -0400] information/ApiListener: My API identity: node01
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 1 CheckerComponent.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 3 Zones.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 1 IcingaApplication.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 2 Endpoints.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 1 FileLogger.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 244 CheckCommands.
[2022-06-16 10:45:31 -0400] information/ConfigItem: Instantiated 1 ApiListener.
[2022-06-16 10:45:31 -0400] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2022-06-16 10:45:31 -0400] information/cli: Finished validating the configuration file(s).
I’m new to my organization and I’m receiving a constant stream of e-mails:
Subject: I2CONFAUTO on node01 failed!
Text:
Failed to run i2confauto on node01. Error : 203:Exception: Unterminated string starting at: line 43979 column 7 (char 1343472)
I tried finding anything named i2confauto in the documentation and when Googling it I get a rather strange zero results. What is i2confauto and what could it be referring to? Node01 is my place holder for the real node name.
