Hi all,
I have a problem regarding timeperiods for users. We have a team of employees who are respectively in charge of the monitoring for a week in a round robin manner. So, I configured a timeperiod for every colleague containing multiple weeks as ranges:
object TimePeriod "escalation-alice" {
ranges = {
"2024-01-01 - 2024-01-07" = "00:00-24:00"
"2024-01-22 - 2024-01-28" = "00:00-24:00"
"2024-02-12 - 2024-02-18" = "00:00-24:00"
object TimePeriod "escalation-bob" {
ranges = {
"2024-01-15 - 2024-01-21" = "00:00-24:00"
"2024-02-05 - 2024-02-11" = "00:00-24:00"
"2024-02-26 - 2024-03-03" = "00:00-24:00"
object TimePeriod "escalation-charlie" {
ranges = {
"2024-01-08 - 2024-01-14" = "00:00-24:00"
"2024-01-29 - 2024-02-04" = "00:00-24:00"
"2024-02-19 - 2024-02-25" = "00:00-24:00"
I reference these periods in the user objects (e.g. period = "escalation-alice"). Unfortunately this does not work as intended, because today (2024-01-15) I get notifications for both, Bob and Charlie, even though only Bob should get notifications (notifications are sent 24x7 to a usergroup which contains all relevant users).
I inspected the time period for Charlie in the icinga2 console (get_time_period(“escalation-charlie”)) and got this:
__name = "escalation-charlie"
active = true
display_name = "escalation-charlie"
excludes = [ ]
extensions = {
DbObject = {
type = "Object"
ha_mode = 0.000000
icingadb_identifier = ""
includes = [ ]
is_inside = true
original_attributes = null
package = "_etc"
pause_called = false
paused = false
prefer_includes = true
ranges = {
resume_called = true
segments = [ {
begin = 1705273200.000000
end = 1705359600.000000
source_location = {
first_column = 1.000000
first_line = 120.000000
last_column = 48.000000
last_line = 120.000000
path = "/etc/icinga2/conf.d/system/timeperiods.conf"
start_called = true
state_loaded = true
stop_called = false
templates = [ "escalation-charlie", "legacy-timeperiod" ]
type = "TimePeriod"
update = {
arguments = [ "tp", "begin", "end" ]
deprecated = false
name = "Internal#LegacyTimePeriod"
side_effect_free = false
type = "Function"
valid_begin = 1705308331.641184
valid_end = 1705446000.000000
vars = null
version = 0.000000
zone = ""
But I’m not sure how to interpret this correctly. Why is there a template “legacy-timeperiod” referenced? I never did include something like that anywhere. What is the meaning of “valid_begin” and “valid_end”? And shouldn’t there be three segments instead of one, as there are three ranges?
The syntax for the range definition is adapted from here.
Further information:
- System: Debian 11 + Icinga2 2.14.0 (installed via icinga2 repository)
- Enabled features: api checker debuglog ido-mysql mainlog notification
I’m not sure how to debug this problem further and would appreciate your help. If you need any more information, let me know.
Thanks in advance!
