Hi everybody,
i want to use the check_snmp_int.pl check to monitor our switches.
The problem is that the interface names for the 48 ports are only numerical. e.g. 1, 2, 3, …48
Now if I only want to check port 8 - 13, I don’t know how to enter it.
I looked in the FAQ and only found the example "./check_snmp_int.pl -H 127.0.0.1 -C public -n “Fast.*0.1[1234]”, which doesn’t help me because it doesn’t say anything more about the syntax.
Regards
Marco
