I am pretty new to both icinga and docker but I love how easy it’s been to get it up and going with docker. However I need to do a bunch of jmx monitoring and the easiest way seems to be with jmx4perl which I have working great from the same docker host using the jmx4perl docker. But now what I really want is to be able to use the check_jmx4perl in the jolokia/jmx4perl container from the icinga docker. So far I have managed to make this work with by_ssh and running it from the host, but that is making things difficult. Is there any chance of jmx4perl and check_jmx4perl being added into the icinga2 docker so that I can just call the check natively? Is there some other way to accomplish this?
Jaaon
